I always assumed that rwkw = rear wheel kw, rwhp = rear wheel hp
kw = flywheel kw, hp = flywheel hp.
Now all the dyno sheets on SAU read in RWKW.
This means rear wheel horse power, right ?
Lets say I got 220rwkw. It means I got 220kw at the rear wheels.
Or 220*1.34=294rwhp and 294*1.1(drive train loss coefficient. 10% is low, but anyway.) = 323hp at the flywheel(crank)
Are my calculations correct ?
Edited by robots
I'd say it would be closer to 365-370 engine hp
One thing I don't understand is than. Lets you got hks2530 turbo. 320hp turbo. And you get 210-220rwkw from it. Which equates to around 340hp. So is there a mistake in the calculations or happy dyno ?
Yeah, 15-25% so say 20% average unless your a Holden or a Ford then the factory will make it more like 30-40%.......lol. The 307kw Holdens don't dyno test at 307kw [that figure is a little optimistic].
Depends on your gearbox, diff and/or CV's, wheel bearings, clutch anything that produces friction and heat in the drive train. The more heat the greater the power loss between crank and wheels.
I use 20% for driveline loss and 0.746 for hp to KW.
So 350hp engine = 280 hp at wheels = 209 kw at wheels.
350hp x 0.8 x 0.746 = 209 rwkw.
In your case that's 220rwkw/0.746 = 295rwhp or 275kw at engine or 369hp at engine. BUT that 20% drivetrain loss becomes less as you get more power with the same driveline. So 369hp might be a tad high. Isn't this a metric society? So you have about 275kw and likely 450Nm of torque maybe a touch more.
Isnt the 20-30% drivetrain loss for a standard car?
206kw flywheel skyline - 25% drivetrain loss = 154.5rwkw which is about right is a drivetrain loss of about 50kw
If the drivetrain doesnt change and all you do is increase engine kw the drivetrain loss figure shouldnt rise very much.
A 300rwkw skyline with an upgraded clutch and flywheel wont change the drivetrain loss much
Therefore 300rwkw + drivetrain loss of 50kw (generous) is only 350 engine kw
If calculate a 300rwkw car at 25% your way off, its a 25kw difference and it grows as the numbers become bigger
:banana::huh::):huh::P:huh::blink::huh::blink::huh:
edit.. I had more emoticons to make my point but..
THE FOLLOWING ERROR(S) WERE FOUND
You have posted a message with more emoticons that this board allows. Please reduce the number of emoticons you've added to the message
lol... owned by zee germans of old
Edited by GTST
Isn't AWKW in a GTR pretty much the same as RWKW. As under normal driving conditions while accelerating, most of the power goes to the rear wheels anyway? So say if a R32 GTR makes 250kw in AWD it will make like 255kw in RWD? However i suppose with engine power there would be a bit of a difference as you would lose a bit more power through an AWD drivetrain with an extra diff/transfer case etc. compared to RWD.
So therefore it would be a bit more at the engine when comparing a 300RWKW car and a 300AWKW car. I think it will be just stabs in the dark to guess how much extra power those components take away in power loss through heat and noise.
Edited by PM-R33
At the end of the day unless you put it on an engine dyno its only estimated, its what is read at the wheels that counts.
An easier conversion from horse power to kilowatts is that 100hp = 75kw, its not exact i know but its easier to do a quick conversion with those figures.
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
    • Nice, love a good GTS-t.  IMHO the factory body kit with the 'aero' front bumper is perfect. Can't improve on it unless it's a GT-R. But it looks like you changed it to the normal bumper?
    • Easy solution to both of those. Put a split bit of garden hose on each one. Attractive and practical!
    • So I guess the next thing to do will be to discuss whether to create a new section of the forums to hold the library (boo hiss?), somewhat undoing the recent tidy up, or if there is a bolt on wiki module for Invision? (I must profess ignorance as to what has been done, what it might cost, etc. I have only briefly googled and seen discussion on adding it.) Or is a wiki even the best way to do what I'm talking about? It possibly isn't. Given that we're trying to re-display forum content, it probably needs to be presented as forum content in forum format, and a wiki would probably struggle with that. A wiki might still be the best way to do some other things, so I'll keep the idea simmering if we don't use it here. Back to the library as "part of the forums". Would we do a single new library? Or put a library thread in each section? Pluses and minuses for each of these, surely. Would we do as I originally suggested, and make the first post in the library be the total of the library, with any reply posts just being the inputs and suggestions I originally posited? Or would we allow posts to accumulate one after the other, each containing additions to the library? Maybe the first post is still an index or something. It's all sounding horribly more manual and messy than my original brain fart. But I hope there's some other good ideas floating around - because every time I come up with a new one of my own I immediately see problems with it.
    • Tips look fine to me......but Boring stuff: Legalities - Vehicle standards notes that exhausts cannot extend to a point where they could cause injury Scary stuff: Mrs cuts open her shin putting stuff in the boot (ensure you have some bandaids and shiny jewellery handy)
