mate i am looking for the weather strip that sits just infront of your wipers in the plastic part under the front window... let me know how much posted to 2571.
Hi mate,
I'm after the power steering/hicas computer unit mounted under the parcel shelf on the right hand side.
let me know.
cheers
hi there guys i bought a 96 s2 skyline coupe to go drifting with...........we never got it done
ive been left with a car that i cant do much with so im wrecking all the parts plus some
extras......im not up all the parts names and how to sell them so pls give me some slack!!!
I will add more parts and photos asap
THINKING OF DOING FRONT AND REAR CUTS DEPENDS ON INTEREST
PARTS LIST
Complete engine with all the bits $2500
Manual gearbox $1500
LHF Guard $150
LHS Complete Door $450
LH Driving Light $200
RH Driving Light $200
RH Headlight $380
LHF Seat $100
Rear Seats $100
Steering Wheels(i have 3 oem) $200ea
As i said if never done this before so lets see how it goes
All series 2 parts avail so pm me if i can help with anything
hi guys still most parts avail wanting to sell all asap so pm me with what u need
Location Gold Coast
Text me only 0411 424 814
chasing the steering column and ignition barrel plastic surround, can you pls post up a pic of it. I am 99% sure this willfit 33 GTR, if in mint nick ill give you $50posted
i will check it out for u i think its in perfect condition
coloum surround is perfect ,no crakes or chips
im stripping car now so all parts are coming off
engine 70,000 klm complete with loom and ecu $1800
Manual Gearbox excl cond $1480
Conversion parts $500
Complete interior
Greddy Intercooler with all piping $750
LH door complete with mirror
3" complete system $1000
All brakes complete
Coilovers
etc....etc...etc....
pm me or
text only.....i cant take calls but can return them after working !!!
0411 424 814
    • You don’t need to use full throttle all the time to break these blocks, 500kw at the wheels in more then enough to break them even with an occasional squirt. Hell I’ve seen them break under 400kw
    • A work around is to install the R35 card style AFM/MAF on the cold side of the intercooler piping and the BOV on the hot side piping. Works well, also you can combat the revs dropping by adding a bit more ignition timing on the idle ignition timing table to slow the rate of RPM drop.
    • Understood. If you dont have a ridiculous limit,  Tune, T's and P's are in check, and arent bashing it all the time and doing the due deligence for maintenance(inc oil analysis) then its pretty safe. 100% agree, let your right food control it to some extent.
    • So these external kits with the machined block for remote solenoid mount will only work on a NEO head and RB30 or RB26 bottom end   For an R33 head on a 26 bottom end the remote vct kit is to resolve RB26 manifold adaptor plates etc  IF you try to use the remote VCT on an RB30 or RB26 bottom end with an R33 head then  you can starve the cam journal??? I have one of these kits from bits I had years ago before plans changed  I don't understand how that tracks with this video   https://youtu.be/RuPiI22Mplk?feature=shared   This looks like I can run the v termite vct kit to feed the VCT on an R33 head on an RB26 bottom end?!?!?   Lol.... don't v have these problems on RB20s
    • Yeah i know that MAF is no no for this type of BoV. The engine has no BoV and "hose/pipes" ..it was all deleted (or probably it was not even on the engine when it was bought  ) It does that "sutututu" noise which i kinda do not want(atmospheric is better IMO...but standalone ECU)  What are the cons of running without blow off on stock RB25DET NEO. It running 5-7 PSI max (it has boost controller)   EDIT: and can Nistune be "tuned" to know there is no BoV to i dont know "know" and be better for a car? I read so many info about no BoV. One guy saying it is bad and hurting the turbo/engine/car and other that it does not...
