Hi everyone... Autposports next event at Wakefield Park is just a few weeks away. There is still around 20 positions still available for those who might be keen to mix it up with a bunch of like-minded guys and girls.
We are infact having some issues with the AUTOsports website and forum at the moment after some mofo hacked it and stuffed up the admin panel. So if anyone wants to register, they just need to send me an email at [email protected]
Also a heads up... we will be holding a timed event at Eastern Creek on Saturday 28th March
Other than email.. you can also ring me on 0408255005
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
