I have for sale a 1994 Magna SE sedan.
Im getting rid of this car as there is just too many cars at my house now especially as i've just bought another Skyline. If no-one snaps this up then it is prob gonna be the lil whore car between me and my friends as we will just chip-in for the reg and keep it as a spare car between us for whoever needs it....
Comes without reg or rwc. Very little is needed for rwc so if you know someone that could help you out with rwc then ur laughing!
Price is negotiable within reason.
So whats wrong with it?
No reg or rwc, sold as is.
Im not sure if its the water pump gasket or the water pump itself may need to be changed as it drops a very tiny amount of water. It DOES NOT overheat tho.
Break pads may need to be changed. But still good.
There is some oil residue in the engine bay but it does not leak onto the driveway. A can of degreaser should see you through the r/w
Tyres seem ok and would prob just pass r/w, either that or get urself some cheap second hand tyres for 25bucks!
There are a few minor dents and scratches consistent with age....but hey its a cheap daily!
So whats good about it?
Black
5speed manual
Cruise Control
A/C
4door
Full electrics ~ All working
Fuel injected
Reliable
Does not blow smoke
Generous boot space
Alarm
Keyless entry
...as is $2,000 ono located in Epping (Northern Suburbs)
The picture provided is not the car. Its just a random to give you an idea of what car im talking about. Hopefully i should have some pics soon.
Thats about everything i can report on the car. Any tests you wanna perform is quite welcome. I have not cleaned out the engine bay or given it a detail so that you can see for yourself how it truly is and to show that there is nothing to hide.
Please feel free to call me if you would like to take a look on 0415 176 014
Cheers
Erno
GTR_STEALTH
https://www.sau.com.au/forums/topic/243499-fs-cheap-runaround-daily-~-melb/
PRICE DROPPED TO 1K FIRM FOR QUICK SALE!!!
I've advertised this at other places also, so be quick to snap this up! I want this gone by Monday avo which is why i've heavily dropped the price.
I urge you to come and take a look. You will see for yourself that it is definitely worth it for a measly 1K
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
