Hi all,
Don't know if i'm posting in the right area.
I've got a 4 door 1998 GT R34, i've had to fix a few things but the next thing needs fixing is the exhaust. Rusted so needs replacing.
Now i see if im replacing it i might as well put something good in there instead of stock.
Now i need some help on where i should be looking and what im looking for (completely dont know.. brother in law does insteas)
I've heard that P platers have a certain restriction on what can be put on the car as it counts as a performance upgrade and theres a limit to what the car can do.
So i'm looking for a cannon to be put on the car but i don't want just a tip i want it to be right so if anyone can give me some suggestions of what i should be looking for to make it still legal for p plater to drive i'd appreciate it.
In Sydney by the way.
Cheers
https://www.sau.com.au/forums/topic/243501-exhaust-help/
Hi all,
Cheers
Put in a straight through 4" Inch exhaust, no cat, biggest cannon you can find and it will sound tuff and will be legal : :thumbsup:
Or if you dont wana hear anymore sarcastic responses lyk that use the search button..
Seems lyk the NA section is just covered with topics about exhausts... GAHHH
IBTL
https://www.sau.com.au/forums/topic/243501-exhaust-help/#findComment-4243604
Yeah tried searching through a bit but couldnt find anything about being legal for p plater etc and to do with same skyline as mine so wanted to see what ppl would say. Thanks for that
its not an engine modification so all the rules that apply to every other driver will apply to you as well when it comes to exhausts.
i.e it must not go over 89 or 90 DB loud.. not sure check with EPA
everyone suggests 2.5 inch mandrel bent for a NA skyline, just get an exhaust shop to weld you a 2.5 inch cat-back pipe to a canon and bobs ur uncle. it will cost ya around $300
u didn't find anything about it being p-plate legal for a car caus it doesnt exist.
welcome to SAU, before posting a question next time, search the forums or GOOGLE it.. ta
https://www.sau.com.au/forums/topic/243501-exhaust-help/#findComment-4243688
I would 'think' that the 'legal' option is to replace it with a replacement OEM exhaust. Of course this isn't always the practical alternative.
Replacing with say a turbo factory exhaust will give you the flow and performance without all the added noise and unwanted attention.
Alternatively, do a custom 2.5" exhaust, but make sure the rear muffler at least "looks" factory, and you use enough resonators to quieten it down, and you will have a good flowing exhaust that won't attract too much attention, and at least you could try and justify that you replaced a rusted exhaust with something that was close enough to factory.
It seems that some cops will pull up any p plate skyline to inspect for illegal modifications; others probably won't harrass you about the exhaust.
The bottom line though is that any modification that affects the performance of a vehicle is illegal under a restricted provisional licence, and try justifying a performance exhaust on a skyline to a police officer who would expect the story to be made up.
https://www.sau.com.au/forums/topic/243501-exhaust-help/#findComment-4243694
I was under the impression that a performance exhaust is still illegal? If I'm wrong I stand corrected. As usual the RTA laws aren't exactly clear cut in black and white when it comes to what can and can't be done.
http://www.skylinesaustralia.com/forums/Pl...33-t238477.html
http://www.skylinesaustralia.com/forums/Pl...ce-t240228.html
Those two threads sum up most of the discussion that's been had here on N/A P Plate Performance which will probably answer other questions you may have.
https://www.sau.com.au/forums/topic/243501-exhaust-help/#findComment-4243719
however if you are concerned with the legalities of modifications - isn't the most logical place your local transport authority? it varies from state to state, so there's no real point asking here; what might be ok for one of the guys here may not be ok for you. so whatever you read on the forums i suggest that you do a bit of your own homework and pick up the phone to whichever legal transport authority it is in your state.
N-dawg put up some good threads, have a look around the forum and see what else you may have missed.
If you want an exhaust, here's some threads to get you started. Please ask any further questions in those threads.
http://www.skylinesaustralia.com/forums/Po...sp-t194033.html
http://www.skylinesaustralia.com/forums/Im...&hl=exhaust
http://www.skylinesaustralia.com/forums/R3...&hl=exhaust
http://www.skylinesaustralia.com/forums/Ex...&hl=exhaust
http://www.skylinesaustralia.com/forums/Pl...&hl=exhaust
http://www.skylinesaustralia.com/forums/Si...&hl=exhaust
http://www.skylinesaustralia.com/forums/R3...;hl=r34+exhaust
http://www.skylinesaustralia.com/forums/Ex...;hl=r34+exhaust
http://www.skylinesaustralia.com/forums/so...;hl=r34+exhaust
Cheers
Eug
https://www.sau.com.au/forums/topic/243501-exhaust-help/#findComment-4243762
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
