ok, so a while ago i installed a 040 pump, followed the manual that i found on here, now i mounted it correctly, and took my time getting it the right distance from the bottom of the tank2-3mm.
it would work perfectly fine for the first 5mins of hard driving, even feels healthier, but after abit the engine starts to seize, like badly. not just a misfire, a full seize and jolts the car. it would be fine under ~2300rpm and idle, but it starts to seize badly after that. now i know its not a misfire because i put the stock pump back in for now and it works fine, plugs are gapped to 0.8mm with ngk copper cold 7's. its all good with the stock pump, but somethings funny with the 040. now i had it dynoed with the stock one and its on 13.5afr's so i need the 040 in there, as its making 170rwkw and i understand its time to change the pump, but now i need to know is it getting to much petrol?
does it need a retune or a fuel pressure regulator to stop this seize?
i need other r32gtst owners to clarify whether they needed a fpr after they installed a 040.
btw it's still running off the stock fuel pump wiring.
thanks in advance, issa.
Edited by phat_man
https://www.sau.com.au/forums/topic/243552-040-fuel-pump-strange-problem/
No you won't need a fpr..
My guess is it's sucking up crap from the bottom of the tank, I'm not a fan of those integral pickup pumps. I went for an 044 with a sock filter setup and have no dramas.
it works pretty well without a fanging, unless i drive it for along time then it seizes as well, so i dont think it would be from that. also its a large mouth there isnt enough dirt in there to block it :P . could it be the wiring?
is your computer standard? as afew reckon i need at least a remap.
thanks.
Mine is remapped now but when the 044 originally went in it wasn't remapped and I still had the RB20 in there.
Did you redo the wiring at all? if not then that is the likely culprit.. pretty sure these pumps don't like the lower voltages and when I had my tuner install mine he rewired it for constant 12v (instead of dropping voltage when at idle etc). Could be just a case of old wiring or bad earth, I would be rewiring :P
Did you redo the wiring at all? if not then that is the likely culprit.. pretty sure these pumps don't like the lower voltages and when I had my tuner install mine he rewired it for constant 12v (instead of dropping voltage when at idle etc). Could be just a case of old wiring or bad earth, I would be rewiring :)
yea thats the other thing, its stock wiring still, but it works fine on idle, unless its cutting the amount of voltage its getting up the top as well.... its weird because the pump works fine for a bit, then it turns to shit.
could it be a faulty pump?
sounds like what happend to me, only my 040 was fine for about 6 months, went to a drift praccy day and by the end of the day it wouldnt rev over 2,500, idled nice, just with any load or any revs it wouldnt run, just couldnt get enough fuel to the engine, got it home, it sat in the shed over night, next day i took it for a run and it went fine for a min or two then started to die again
now have another 040 in it and its been fine for a few months with a few drift days, i put it down to a dodgy pump
is your 040 new or used? try another 040 and see if its any different
i have my pump wired up with 12v all the time and stock fpr
Edited by tp1gts2
id suggest put your standard pump back in and use it as a lift pump, mount the 040 externally with a surge tank fed by the standard pump.. aslong as you use good hose clamps and mount it all securely you wont have any dramas.. for cops, mount it in a sealed perspex box..
you already have the bosch and standard pumps and you can get a cheap 2nd hand surge tank... much better value than a stooopid subwoofer.
thanks for that appreciate it. the problem is i dont know anyone else that has a 040.
Redo the wiring.
yea i think thats what imight have to do, except do i leave the stock triggers in there (the ones that turn the pump off when theres enough fuel and stop it from pumping fuel when you crash... etc.. etc... or is it just a straight hard wire?
lol i dont have any subs and dont plan on getting any.
i dont want to have to go external pump, seems abit to much for the amount of power i ultimately aim of having (~230rwkw) so i think the internal should be plenty... only if it worked....
who suggest's a good place in sydney to redo the wiring for my fuel pump on my r32?
btw thanks again for the help guys, appreciate it.
Is it even possible to mount an 040 externally? I wouldn't think so with the integral pickup.. that's what the 044 is designed for but you can run them in tank with the sock filter setup.
the 044 seemed like overkill for what i wanted.
but now the 040 isnt working properly...
so can someone confirm that they needed a rewire to run a 040 in a r32 gtst?
thanks, issa.
you dont NEED to do the wiring, it would be better, but i dont think it will fix the problem your having
yea thats what i thought.
and no one else seems to of had this problem, except the ones with faulty 040's, so i think that might be the case...
whats the go with warranty, i havnt had it for over 12months yet, should i just take it back to where i bought it and do they have to give me a replacement? keep in mind ive had it for around 3 months, but it hasnt been in the car for more then 2 days, it just took me a while to get around to putting it in.
there is no overkill with fuel, it will just return to the tank if its not needed.. i had an 044 on a near stock 33, came in handy when i wanted a bigger turbo, didnt have to worry bout fuel issues. as for noise... well, it wasnt that noisy, but to be honest, i loved the noise.. i didnt have any smell issues either..
why cant you run an 040 externally??
the way it picks up the petrol is different to the 044, it just has a screen along the whole bottom of the pump that sucks in the petrol, unlike the 044 that has a sock where you can control where it sucks.
so the verdict is faulty pump? i hope im right, im going to take it back tomorrow.
for wiring - see the FI Quick Red Guide. There is a thread linked from it on how to correctly wire the pump.
Failing that, you could simple test with a fuel pressure gauge. Will tell you if its failing or not while your driving (the gauge sticks out from under the bonnet). 1min to install, 5mins to test.
You don't need a surge tank, certainly not in a street car with your level of mods/power etc.
Check the pressure if thats it, fix it, if not... check the mounting again just to be sure... if all of those aren't it... could be a multitude of things
    • Nah, if I need to fit people in a car I'll just use the Mrs car, the MX5 is perfect for what I need as a fun little sports car for fun on the street As for getting in and out of the MX5, I have no issues as I am a short arse who does lots of mobility training 🥷 If anything, I have been looking at Daihatsu Hi-Jets for a work hack, I helped one of my mates move some stuff with one recently that he picked up from Just Jap, it was a little ripper and plenty big enough for what we needed, it would also be super handy for me as I do alot of gardening, and plan on having some veggie patches and native gardens in the place I buy next year when I retire I did alot landscape gardening and growing veggies prior to my current job, and loved it, and that is a hobby that can keep me sane in my retirement, and as such, the little 300kg load capacity would be more than enough for what I need it to move around I have been looking at utes for just this purpose for a while now, and a near new 2024 Hi-Jet can be had for under $30k And I would rather look at a quirky little Hi-Jet than pretty much any other little ute, well, apart from a Brumby, I love the little Brumby, and weirdly have never owned one yet I was going to buy a heap of raffle tickets to try and win the Brumby that MCM built for Subaru Australia, but sadly I totally missed the raffle, I even filled in some form to be told when the raffle started so I could buy tickets, but to my dismay I was never contacted and found out I missed it when I was randomly googling Brumbys last year... #conspiracy  Maybe I should just buy a Brumby for a little "work hack".....LOL I use to be indecisive, but now I'm not sure
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
