Hey all
Have a few skyline bits i need to get rid of asap Prices are negiotiable
R33/R34 Blitz Jasma exhaust.
3 inch cat back......nice note.
Im after $250 for it.
29102008599ia1.jpg[/img]
w320.png[/img]
Bee R rev limiter
After $300
12 inch Cadence Beast subwoffer
In cadence box
600 Watts RMS 1200 PEAK
After $130
https://www.sau.com.au/forums/topic/243570-misc-skyline-parts-must-go/
Hey - Exhaust still for sale? Will i have modify anything to bolt this up?
I'm interested in the Bee R and Exhaust if you still got it. PM me ur Best price please...
  • 3 weeks later...
