That's what I used to clean just inside the ports... but I was too worried about debris/bits of metal bristles getting in the cylinders to go any deeper
Vacuum clean as u go.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4258007
  • Replies 51
I finally got the manifold off. The back banjo bolt on the turbo nearly deconstructed my shoulder reconstruction. No lol.
The turbo appears AOK. There are four broken studs to get out.
Nos 1, 2 and 6 exhausts were all leaking past the gaskets. I got a new set of gaskets, studs and nuts from Nissan. $247.00. I dont know yet how much to remove the studs, I just hope that they can come out without taking the head off.
In the meantime I am enjoying driving my "New" RMR30.
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4262475
Wow, sorry to hear you had a much harder time getting your manifold off then I just did. Seems that this little procedure is much harder to perform on an R33 engine than an R34? Maybe it's just because of K's/age; how many K's had yours done? Mine was 110,000...
I bought new exhaust manifold gasket, studs and conical-locking nuts from Nissan and my total was ~$192; I know that turbo-manifold gasket is around $40-ish though, and a dump gasket is the same.
The turbo water and oil lines SUCK, in my opinion... I'm going to do as suggested and take the solid oil line to pirtek and get a braided hose made, hopefully around $60-ish, to make things a bit easier to put back together. Hopefully I won't have to use banjos with it still, because they also suck (fiddly copper washers to get on).
The temptation is there to replace so many things while it's apart... just think... all that work to get back here again to change turbo, gasket, manifold, dump, EGO sensor etc. etc.
Edited by DaveB
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4264745
Yippee. Justin came over and got the broken studs out in situ. If anyone needs a similar job done call 0407768450.
Incidently his set of L/H drills, 4 off, cost $350.
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4268748
I read that you have your turbo back on... how'd you go with it, are you driving the car again? Was it a GCG hi-flow you put on?
No, the turbo was OK, so I put it back on. I am pretty sure the problem was a loose hose on the turbo inlet rather than the leaking exhaust gasket. The noise only occured when the boost came on. With the brakes on I could run up to about 5 psi and it was very noticeable, at about 2k+ revs. At 3-4K in park, ie no load, no boost, the noise was not apparent.
Finished the job yesterday and it drives like a Stagea should. I also cut the corrugated part of the hose between the AFM and the turbo.
I will keep the stock turbo I bought and get the mannifold repaired so they will be good to use if needs be.
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4291763
glad to hear you're now one of the lucky ones who's factory ceramic turbo is _not_ whining its head off!
Did you replace the corrugated part of your inlet pipe with a metal tube (as mentioned somewhere here in a '5 minute DIY' or something similar)? Also helps stop 'sucky closed under boost' though you probably won't have that problem with the factory turbo I guess.
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4294679
I did the inlet pipe bit.
Each time I do a bit og mod the car gets better. Went for a run out the back blocks today. Very satisfying.
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4295573
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
