SORRY GUYS, BUT DUE IN IN-SUFFICIENT NUMBERS, THE TRACK DAY IS CANCELLED
Guys,
Just seeing if any of your SAU guys/gals are interested in making your whales go around corners at an upcoming track day in Collie.
SilviaWA is trying to get numbers together for a track day on the 27th of September at the Collie Track. $50 per person will be the cost.
So, who's up for it? Or do you boys only go in straight lines?
https://www.sau.com.au/forums/topic/24362-track-day-fun/
  • Replies 60
im thinking about coming along to this one, the last one I went to a i had a ball (month ago), or ill be making it to the AFARCC one a few weeks following that.
if so, ill be bringing my gf's GZE rolla aswell for some fun :(
Shaun
https://www.sau.com.au/forums/topic/24362-track-day-fun/#findComment-520090
I think the temp 1 day CAMS is alot more than $30. I thought that the SilviaWA club had the CAMS insurance thing covered. Hmmm.. Put me down as tentative for now. If I get pushed out of the list by others so be it.
Cam
https://www.sau.com.au/forums/topic/24362-track-day-fun/#findComment-521062
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
