+7 offset ??? good luck. If yours is lowered, be prepared to at least roll the guards or add a FRP guard extension. Most GTR wheels' offsets are around +15, where do you find these rims? Sounds like one of those VIP chrome wheels off a japanese VIP-styled sedans?
Normally in Options magazine Japan, for 350Z or V35 around +20-25 offset is considered quite 'aggressive' already to the standard's offset which is around +35-38.
+7 means your outer edge of the rims will stick out around 3cm outside IF your aftermarket rims is also 8" in width like the OEM rims.
However you have 8.5" and 9.5" that means it will stick out more around 4cm front and around 6cm rear. Grab a ruler and stick it onto your std rims,
and you can imagine how much those rims will stick out.
You can install a narrow tyres to get away with it, stretching the sidewalls so it really looks like those VIP cars in Japan, with a mad negative camber.
Although I doubt it will be legal here to run your car with such camber and rim/tyre combination.
Alternatively you can remove your front guard panels and cut the rear qtr panels, transform the V35 to a go-kart/F1 style, or a Caversham open wheeler club racer :) Don't forget to chop off the roof and install a roll cage.
https://www.sau.com.au/forums/topic/243623-wheel-fitment/#findComment-4245480
Thanks for that :)
"where do you find these rims? Sounds like one of those VIP chrome wheels off a japanese VIP-styled sedans?"
Nope just a hot set of VSKF's
As far as +25 being aggressive hmmm. I use to run x9 +15 front and rear on a 180sx with stock guards.
What sort of sizes should i be looking to get, offset and width wise.
Edited by mxtcy
https://www.sau.com.au/forums/topic/243623-wheel-fitment/#findComment-4245489
Any pics... sounds really MAD, probably more of a show rims rather than a practical daily driving one, I'd imagine it'll constantly rub your guards or scrape the gutters...
Check the offset with offset calculator here:
Std V35 rims are 8" with +35 offset front and +38 offset rear. I'm not sure if rear is 8.5" but you can get an idea how much they will stick out using that calculator
http://www.1010tires.com/WheelOffsetCalculator.asp
https://www.sau.com.au/forums/topic/243623-wheel-fitment/#findComment-4245496
actually based on the 18x8 +30 stock rims the ones you want will sit 29mm out at the front and 42mm out at the rear. If you have the stock 18s go measure the tyre to guard space and you will find that there is plenty of room there without needing to run stretched tyres.
A +7 offset would be very aggressive only if you were running 9.5 fronts and 10.5 rears.
https://www.sau.com.au/forums/topic/243623-wheel-fitment/#findComment-4245714
i have some 20x9.5 front and 20x11 rear on the way for v35 coupe with +25 offset all round. I will be lowered on tein s-techs and only plan on rolling the guards to fit. You should be fine with that combo, you may need to roll the guards at worst
https://www.sau.com.au/forums/topic/243623-wheel-fitment/#findComment-4245717
hi mate, can you PM me where you are able to get wheels of this size? is it costing you an arm and a leg?
https://www.sau.com.au/forums/topic/243623-wheel-fitment/#findComment-4245795
are finding 20" tyres easier than 19" ? initially I was going to 235/35 & 265/35 on 19 as those are the closest compatible size but looks like will have to go 245 & 275
Hi ,
I have a question relating to this. My car has front 245/35/19 yokohama and 275/35/19 rear. Now im looking for new tyres for the front as they are pretty worn and i found a great deal on some pirelli's p-zero rosso. But the size is 235/45/19 instead of 245/35/19. Will these tyres fit without rubbing the guards and will it throw my speedo out ? The car has not been lowered and is factory height from what i can tell.
https://www.sau.com.au/forums/topic/243623-wheel-fitment/#findComment-4249244
The 235/45 will be 2cm bigger in radius compared to the 245/35 you had.
Although it may fit however the circumference will be around 5% bigger than standard so that is not really recommend to have aftermarket tyres that is bigger than 3% circumference, however I'm not sure where the speedo reading is taken, possible from around the diff area, so it may not affect your speedo speed.
https://www.sau.com.au/forums/topic/243623-wheel-fitment/#findComment-4249353
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
