Slim takes some aweosme shots, he is doing mine next race day :)
hey chris ,
ive been meaning to come on a track day with SAU Guys when is the next one ? may come down .... anyone else can help me i kind of want someone who has some spare time during the week at night who wants to meet somewere take some snaps ....
https://www.sau.com.au/forums/topic/243624-hey/#findComment-4245559
my god that is a nice looking GTR. I know this is completely unrelated but congrats on having such a perfect vehicle mate.
If only i was good at photography..could see this thing in the flesh :P
Hey Nick ,
Thanks for heads up , when i bought it it didnt have the wheels or the kit but had the engine mods Turbos, ECU, Fuel , Injectors ETC . Wanted to make it look like a Z Tune , if you can think of anyone let me know thanks ....
https://www.sau.com.au/forums/topic/243624-hey/#findComment-4246690
Whereabouts in NSW are you Moei? I'm based in Lake Macquaire about 45mins south of Newcastle so if you're interested I can shoot in Newcastle, Central Coast or Northern Sydney. :blink:
Hey Thanks For your reply
Im located in Sydney Bankstown Area , But i dont mind driving up to meet you somewere , mabye not newcastle somewere more closer to sydney you have anywere in mind ???
Moei .....
https://www.sau.com.au/forums/topic/243624-hey/#findComment-4248623
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
