hey, i just bought a set of 20x10.5, 0 offset work meister's, and they dont fit over my brakes, they are 370mm endless 6 pot racing
i need some custom hats made to push the rotor/caliper 10mm in so i can clear the brakes! atm im runnign 8mm spacers but they sit ridiculously out lol
any help/info to who i should ask/see, need to be in sydney or even in brisbane/gold coast
thanks!!
Just get it dropped off at Race Brakes in Wetherill Park or Penrith Brake and Clutch (gavsport)
are they called Penrith brake and clutch now? i remember the days when they were 'Specialised brake and clutch' and their shop was in St Marys
these guys were the one of the first and IMHO still the best, hope its still the same guys
Edited by shoei
i spoke to specialised today, and they said they can do it so can racebrakes, but racebrakes want an arm n a leg to do it lol i found a place in qld, they said around 350 per hat... racebrakes is almost double!
you might want to get a price for the caliper adapters as well these are usually $$$$
but i think u might be better off selling your wheels and buying something that fits
Hats wont move the caliper, as Shoei said - there is more to it, dog bones required or spacers
Penrith brake and clutch can do this too, did plenty of coating work for thier custom brakes.
Specialised brake and cluth (gav sport) is in penrith now too - in peachtree
