Hi All,
Several bits and pieces for sale from my old GTS-t. Get 'em while they're hot! :)
ITEM 1: First up is a set of standard R32 GTS-t wheels. They're in really excellent condition (just grubby) with almost brand new Pirelli tyres (95%+ tread).
Stud pattern is 5x114.3, and the wheel size is 16"x6.5" +40. Excellent for track days with the near new tyres. Or a really nice addition to your R31.
I'm looking to get $500 for these. That's cheaper than buying the tyres by themselves. :banana:
ITEM 2: Standard R32 GTS-t springs. Great condition, nothing to worry about. Clear those defects! :banana:
Give me $50 and they're yours.
ITEM 3: Instrument cluster for an R32 GTS-t. This is out of a series 2, so it's got the grey faced dials. Also comes with a white LED backlighting pack from Dan's for sale thread on here. Working perfectly, has 141,xxxkms on the dial.
Take it away for $80.
ITEM 4: R32 GTS-t speedo cable. Nothing wrong with it. Original one that came with the car, so it has a slight amount of 'wobble'. Works fine.
Yours for $30.
ITEM 5: Very basic turbo timer. Brand is 'CaliTec' and I believe it's Australian made. Switchable between 1, 3 and 5 minutes. Can be fitted to any vehicle. Working fine when last removed.
Going to a good home for $20.
That's it, for now. I've got an R34 GT-T intercooler that may go up soon. As well as a TurboSmart boost controller, if anyone is interested.
At this stage all items are pickup only, but I'm prepared to talk postage with those who are really desperate (for some of the smaller items).
Contact me via PM if you need to, or post in this thread as I'll be checking it as often as I can. More pictures can be arranged if requested. I'm a trusted trader on SAU, and plenty of other online communities. Feel free to ask any questions. :banana:
Cheers!
Ryan
Edited by HuH
https://www.sau.com.au/forums/topic/243653-r32-gts-t-parts-accessories/
It's a TurboSmart job. Single stage switchable controller, so you can have stock boost plus high boost and select between the two. It basically looks like this, just a bit bigger:
SPEEDO CABLE IS SOLD.
I'll get back to you about the boost controller.
The intercooler is a standard R34 GT-T intercooler. Direct fit into an R33 GTS-t. It came out of a 2001 model '34, and it's in great condition.
  • 3 weeks later...
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
