Hey i have a HKS EVC 5 for sale, was purchased of SLIDE shop who is a trader on this site a few weeks ago. I took it out the box and ran the wires in my GTR but as i received my blitz dual SBC controller back (i find it easier to set up as i have used them for years) i have reverted back to the blitz item. THis thing has literally powered up and thats it, still have all documentation etc to go with it not a scratch on it. Can be viewed before sale and pic up avalible. It retails for 880 delivered on nengun now and 750 on slide, im after 650 ono. Will get pictures tomorrow for you all
can contact through PM here
will ship anywhere/pick up
bank deposit payment
cheers
https://www.sau.com.au/forums/topic/243657-hks-evc-5/
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
