Another new R32 owner! (Beware...Newbie questions!!)
Originally posted by doxximus
ur ascii sucks
hahaha shut up doxx!
my ascii canes all... im the ascii porn king~!
but yeh, those were meant to be dials...
who's 32 has side indicators? wahts the deal with those? some have some dont...
edit: ur dave grohl sucks!
(late comeback...)
I believe R32s 'gain' side indicators during Australian compliance? All the pics I've seen on prestige etc. of R32 skylines still in Japan have no side indicators.
That's why they're nearly always those dodgy little square things that look like they belong on a small trailer or something??! Keeps the cost of compliance down no doubt!
And also you'll notice that they're often in different locations, some have the indicator right above the GT badge, while others are much higher, almost in line with the top of the wheel arch (like mine).
coco69, I'm guess whoever complied your '32 decided not to put them on! Same way the ppl who complied mine decided not to put in that crappy dash illumination dimmer switch (read - dollar fifty dick smith job) that is also required for compliance - Good I say, I don't want no damn holes in my dash, no matter how small and concealed!! :(
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
