Just wondering if 243Hp @ the wheels on 10psi with the current setup is decent as i just got a dyno tune today and not sure what i should expect out of my stock turbo. So if you got a stock turbo or running an safc cos i'd like to see how much i can squeeze out my safc.
could you post your dyno results! dyno graphs also if available =)
mods are
-autobahn fmic
-3" hks dragger
-walbro pump
-apexi induction
-safc2
cheers
I got my car tuned yesterday And she pulled 179KW ( 240hp )
Running-
Blitz Intercooler
APEXi RSM Metre
APEXi SAFC metre
Splitfire Coilpacks
Full Jasma 3" Stainless exhaust
Only running standard boost till i get a Boost controller...
Yeah that right on the money having a power fc with those mods wont make alot of difference power wise.
Bumping up to 12-14psi wont improve power on stock turbo, wouldnt be good for turbo either. It will improve mid range however.
280hp would be bs for these mods John
beg the differ seen plenty of "happy" 33's make 270 272 276 278 hp on many occasions just depends of where you go, you all know the story...
next mods should be
high flow cat
pfc
z32 afm
bosch pump (get rid of the walbro item but it will do for now)
decent clutch if not changed already..
i have around 200rwkw on a stock turbo ran on a mainline dyno . i know running 13 psi isn't great for it but hasn't died yet. waiting for turbo to choke it self soo i have a good excuse to install my new one in. but still waiting for it to die :D and its not showing any signs so far of it giving up.
put it on a happy dynodynamics dyno and u will get 280hp on stock turbo.
Edited by tets
have you got a graph showing a/f mix? its sounds pretty right but you could bump it up to 12psi for a little extra power. mine made 200kw on 12psi but I have a jap remaped ecu picking up the timming.
very happy!!!
after the tune, to be honest i wasn't very happy at all with the results because the car felt like it pulled more before the tune.
i thought to myself.."this cant be, it's just been tuned..the car can only get better not worst"
not being able to convince myself i got the tools out after work and popped the bonnet open.
- intercooler piping..check! (all tight)...
- vacuum lines had no apparent cracks and also sprayed a little amount of water, no bubbling..UNTIL i got to the bov vacuum line,
few bubbles starting to appear, looked closer and it had alot of cracks and visible wearing. cut a piece off and refitted, and then also saw that the hoseclamp wasn't tightened. it was LOOSE, i could pull it right off.
- stock bov..wiggled it around abit, what the? its shaking and then pop went the top bolt into my coilpacks, got the sucker and tightened it back on.
- everything else seemed fine so i went for a drive
it pulls like a train now!!!!
not sure why my tuner didnt pick it up though?
quite angry cos now it means it was just a waste of a tune..would it be best to get another tune?
Edited by Richy08
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
    • Cheers mate. Seems some people get lucky others don't. It looks like the motor was detonating (to be expected if it was overboosting I suppose) as the pistons had a lot of detonation damage, and the bearings were stuffed. The bores were very scoured too, not sure if that's from the pistons or bits of ceramic turbo. By the by now. Have been trying to avoid the rabbit hole too much on the rebuild, and there's been a few hurdles along the way, but with any luck I'll have the car back soon™. Might even pop up a thread then.
