Just wondering if 243Hp @ the wheels on 10psi with the current setup is decent as i just got a dyno tune today and not sure what i should expect out of my stock turbo. So if you got a stock turbo or running an safc cos i'd like to see how much i can squeeze out my safc.
could you post your dyno results! dyno graphs also if available =)
mods are
-autobahn fmic
-3" hks dragger
-walbro pump
-apexi induction
-safc2
cheers
I got my car tuned yesterday And she pulled 179KW ( 240hp )
Running-
Blitz Intercooler
APEXi RSM Metre
APEXi SAFC metre
Splitfire Coilpacks
Full Jasma 3" Stainless exhaust
Only running standard boost till i get a Boost controller...
Yeah that right on the money having a power fc with those mods wont make alot of difference power wise.
Bumping up to 12-14psi wont improve power on stock turbo, wouldnt be good for turbo either. It will improve mid range however.
280hp would be bs for these mods John
beg the differ seen plenty of "happy" 33's make 270 272 276 278 hp on many occasions just depends of where you go, you all know the story...
next mods should be
high flow cat
pfc
z32 afm
bosch pump (get rid of the walbro item but it will do for now)
decent clutch if not changed already..
i have around 200rwkw on a stock turbo ran on a mainline dyno . i know running 13 psi isn't great for it but hasn't died yet. waiting for turbo to choke it self soo i have a good excuse to install my new one in. but still waiting for it to die :D and its not showing any signs so far of it giving up.
put it on a happy dynodynamics dyno and u will get 280hp on stock turbo.
Edited by tets
have you got a graph showing a/f mix? its sounds pretty right but you could bump it up to 12psi for a little extra power. mine made 200kw on 12psi but I have a jap remaped ecu picking up the timming.
very happy!!!
after the tune, to be honest i wasn't very happy at all with the results because the car felt like it pulled more before the tune.
i thought to myself.."this cant be, it's just been tuned..the car can only get better not worst"
not being able to convince myself i got the tools out after work and popped the bonnet open.
- intercooler piping..check! (all tight)...
- vacuum lines had no apparent cracks and also sprayed a little amount of water, no bubbling..UNTIL i got to the bov vacuum line,
few bubbles starting to appear, looked closer and it had alot of cracks and visible wearing. cut a piece off and refitted, and then also saw that the hoseclamp wasn't tightened. it was LOOSE, i could pull it right off.
- stock bov..wiggled it around abit, what the? its shaking and then pop went the top bolt into my coilpacks, got the sucker and tightened it back on.
- everything else seemed fine so i went for a drive
it pulls like a train now!!!!
not sure why my tuner didnt pick it up though?
quite angry cos now it means it was just a waste of a tune..would it be best to get another tune?
Edited by Richy08
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
