hahaha! You can still have fun without a license lol!
yer that's my car. mmm... it's ok for what it is, only running 13 psi at the stage till i work out that funny thing called traction
Only ran a 13.05 @ 108 mph.
A little dissapointing as a really wanted a 12 and i know the car is good for it... but i learnt a few things so me going back to fiddle, that should help throw it into a mid 12 before the end of the year :)
and SLYWPN... R34's have Rb25's :(
but mine is an R33 Series II RB25.
i reckon it's a shit pic though.
Oh.. yer i aint changed it...
1) i'm too lazy.
2) i'm not going to go round saying what i've got lol! Bit of stealth
but it's over 200rwkw. And that's with the Factory T04e :(
The turbo is sort just hanging on for the ride at the moment. Give it 15-17psi and it'll produce some decent results.
I need bigger injectors before that can happen though.
But that will probably be next year as i wanna do a few other things first, Brakes/wheels/motor re-build
what do you want the motor rebuilt for? RB25 should be good for 250rwkw stock with no problems.
I just got bigger injectors and a like new R34 turbo that hopefully should produce the goods on the BMT dyno on thursday/friday.
I'm hoping for at least 185 or so.
2 reasons...
1) i'm already close to the engine limit now. I'm not there but i'll be there with more boost very easily.
2) The opportunity has come about, so i'm gonna take it.
A mate was kind enough to offer a hand to do it so it's only parts that'll cost me aint it wont kill my rear pocket now :(
But i will be going further than 250rwkw, so getting it stonger wont hurt while i have the chance.
well at the end of the day... how do you know where the motor has come from?
it might have had the ass thrashed out of it! who knows.
with a rebuilt motor, stonger internals, i KNOW where it's come from and what life the engine has had after the rebuild.
why bother taking an RB26DETT of dubious origin for $5k+ .. when you can take an RB30DE for less than $500 and for another $5k more have it done exactly the way you like it and actually stronger than an RB26DETT anyway...then you strap that single T78 on it and hold the hell on..
RB26DETT in 2WD configuration is just a bit overdone and for little benefits..
Anyway,guess what i've been reading. :P
http://www.skylinesaustralia.com/forums/sh...&threadid=15420
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
