Hi all,
Just a little advice in terms of what cams would be worth running in the 25/30 build i have just started.
The head is a R33 RB25, and the intention is to disable the VCT and run adjustable cam gears. What cams would be a good option, or are the stock RB25 cams okay.
The current RB25 motor gives a little over 235kW ATW, and have saved my new SARD 850cc injectors to go in the new hybrid block.
Other parts will include:
CP forged pistons 9.0:1
1.4mm Head gasket
Forged pistons - make undecided
Adjustable cam gears
T04z or GT 3540 undecided
SARD 850cc injec
Thanks
https://www.sau.com.au/forums/topic/243692-poncams-or-larger-for-rb2530/
Hi all,
1.4mm Head gasket
SARD 850cc injec
Thanks
anyone got an opinion?
I'd match the cams to the turbo.
GT35r/T04z you really want to start looking at cams with decent lift (9mm+) with a mid 260 duration to make full use of the turbo on pump fuel.
Ideally for street gt35r/t04z a mid 260duration and 10-11mm lift but thats not easily achievable with the hydraulic head. :cheers:
Go beyond 9mm lift and there are issues with getting valve springs that can physically fit and do the job without coil bind problems.
A good bet is to get the stock head and springs measured up so you have a known base to work from. There are good, useable cams and springs available to suit RB25 heads, but you'd likely need a 26 head if you want to be able to use some serious cams easily.
Neo = solid followers.
Grab some suitable springs from performance springs and shove in a set of cams with decent lift. Decent lift and they make power so much easier on less boost with pump fuel and you don't need to ring its neck by running long duration cams to try and make the power. 8000rpm is really all you need with peak power sitting just over 7000rpm and holding nicely to 8k.
on the subject of higher lift with a neo head
has anyone worked around the issue that Spool found with any lift over 9.xx mm lift, and exposed oil galleries (if my memory serves me correctly)?
intererest to know this aswell because if my cams are choking then will need to upgrade to something bigger. And 8k rpm is plenty for me.
as far as i know
the crank bent on the dyno while increasing its rev limit
and it runs a ross balancer
most of the workshops here dun wanna know about the 26/30 (yay wa)
they either suggest a stroker or stick to the 2.6 and rev it a bit more
Im planning on
CP pistons
Spool rods
Cometic headgasket
Acl shells
crank collar
arp headstuds undecided 11mm or 12mm
arp main studs
N1 oil pump
4wd adaptor plate
ati balancer
will/wont this rev safely?
either that or i might just buy an engine from proengines/lewis engines
Edited by R32 Driver
The workshops don't want to know of the 26/30 because they have no experience with them.. :P
The cranks simply do not bend they break oil pumps so possibly a build issue due to lack of experience with the rb30's.
Speak to Rajab racing and a few of the other workshops (inc. proengines) that build serious RB's they know how to get them to hold together at high rpm. i.e grub screw the crank.
There are a few tricks to be performed its not just a matter of giving the rb30 a refresh and a good balancer then hope for the best.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
