I know this topic has been discussed in previous threads, but i cant find the answers i need
My car has been fine until a few days ago, after i stopped at the servo i started my car & noticed the HICAS
light was on & this caused my steering to be heavy. I tried to restart the car & the light stays on
however this is where things get wierd, if i leave the car for a overnight or while im working (approx 8 hrs)
i can start the car & the light will stay off and steering will be normal, but if i was to turn the car off & restart
the light would go on & steering would be heavy again, it seems the car likes to have a rest before it works properly :(
Will driving the car with heavy the HICAS light on & heavy streering cause any damage?
I know a lock bar would probably be the way to go? will this make my steering as heavy as it is with the HICAS light on?
Is there a simple way to fix this? at least until i find the time to fit a lock bar?
i have already tried cleening the contact on the HICAS but with no sucess...
any suggestions??? any input would be greatly appreciated :P
https://www.sau.com.au/forums/topic/243696-hicas-light-on-heavy-steering/
see if you can do a HICAS diagnostic. it should be able to narrow it down for you. but by the sounds of it, its leaning towards being your vehical speed sensor. it tells the car that its moving and to bump up the pressure to the powersteering system, and it is also needed for HICAS to function. if you just throw a HICAS lock bar in i'd say you'll still be stuck with heavy steering. but yeah, start by doing the HICAS diagnostic and see what it says, there is a tutorial on how to do this in the tut section.
Thanks for the quick reply, i think you might be right about it being the pressure to the power steering system, so the speed sensor could be causing the problem, do you know where the speed sensor is located?? i have tried the HICAS diagnostic & the HICAS light didnt flash, maybe i wasnt quick enough??
^^Also check the power steering fluid, Hicas using it aswell.
Fluid level is fine, but i think the hoses need replacing soon...could a slightly deteriated hose cause a pressure drop & HICAS light to come on? I would have thought if there was a leak sufficent to casuse a problem the fluid level would be dropping dramatically?
PS: the car is a Series 1 R33, it also has a Wolf 3D aftermarket computer (plug n' play)
is the speed sensor on the gearbox, speedo, connected to computer??
sorry if this seems like a silly question :P
Take it to your mechanic and get them to plug in the diagnostics computer to trace the fault.
It will pick up all the sensors and give you a reading.
Its just a matter of isolating each point till you narrow it down.
power-steering fluid is only relevant to r32gtst...
im pretty sure 32gtr use super hicas..
which comes standard in 33gtst onwards..
so its done by an KYB motor..not hydraulic!!
correct me if im wrong...
so pwr-str fluid wouldnt have anything to do wit it!
sound lik u need to do an hicas diagnostics..
hey mate ive the exact same problem that you're having. I park my car and get some food, when i come back and start my car the
HICAS lights comes on. I leave it for a long period of time like overnight etc... it goes off, and now it jsut comes and goes randomly its
super weird. Im driving a R33 non turbo, anyone knows how does the HICAS work on this one? Is it fully electronic as well or does it
work with the fluid?
cheers!
cheers!
oh good question..lol
well as far as i know..R33 have super hicas..which is the same as as 32GTR..
this runs off a electric motor...and i Nissan used KYB motors...
have a look under ur car and see if you can see these motor on the hicas unit behind the diff...
the motor should have a sticker on it..
sounds like u need to run a diagnostics..there is a way to do it..just search...
  • 4 weeks later...
Ive just run plugged in the standard ECU and run a diagnostic system check
ps:diagnostic computer will not communicate with aftermarket ECU
The readout from HICAS was - 25 Engine Rev abnormal signal
Does anyone know what this means?? Would it be to do with reverse (speed sensor) on speedo/gearbox
The error code i chased up on this site for HICAS diagnostic Codes 1993-1999
and came up with: 25 Rear sub sensor input not present
would this be the smaller of the two sensors to the right of the HICAS motor
i guess the sensor or plug could be faulty??
Anyone had the same problem?? or any suggestions on what i need to do??
Thanks for everyones input! :P
32gtr is hydraulic.
  • 1 month later...
I'm having the exact same problem with my R33 Gtst S1. It just starting doing it one day and it seems to happen every now and then. It seems to happen on warmer days and doesnt happen at all on cold days which is quite weird. When it does happen the HICAS usnit seems to be quite hot aswell. Has anyone found a fix for this yet? Some more info would be great!
Cheers
Sounds like your HICAS pump is on its way out... The steering gets heavier and the light comes on when the secondary pump isnt working.
Mine had the same problem for a while, just buy and fit a lock out kit and pull out the entire HICAS system (or pay someone who knows how to do it). :happy:
Mine had the same problem for a while, just buy and fit a lock out kit and pull out the entire HICAS system (or pay someone who knows how to do it). :D
It's a 33.. they have an electronic HICAS system.
If you bothered to read the whole thread you would have known this.
But, +1 to removing HICAS, one of the best things I ever did to my car.
  • 2 months later...
  • 7 months later...
Before any more complicated answers, one question..
Have you performed a hicas diagnostic on your car?
A) Yes, and let us know the results..
B) No, go and do one, will find the how to in diy and tute section.
Thank you for your time.
    • https://www.carsales.com.au/cars/details/2002-holden-commodore-ss-vx-ii-auto/SSE-AD-18219062/?gts=SSE-AD-18219062&gtssaleid=SSE-AD-18219062&pageSource=details
    • does anyone know tie rod torque setting and anti roll bar for r34? Is there a workshop which shows various components torque setting?
    • Hi    have purchased pair of eibach wheel spacer as I couldn’t fit set of wheels I bought for my car due to it catching caliper.   I know I need to cut the bolts on my discs so they sit flush with the nut supplied but the nut doesn’t sit all the way into the groove meaning wheel would not directly fit onto the spacer rather the nuts. Any thoughts?   See pic   https://ibb.co/VJK5w5G
    • Nah. There's not shit tonnes of pressure in there. Just drill with a 1.5mm drill or something equally tiny. When the drill goes all the way through thee gas will start to come out, but with such tiny path through the flutes of the drill bit, it won't be at all dangerous. You can be as paranoid as you like from then on. I'd just pull the drill out while keeping my face out of the line of fire. But then, I spend half my time looking into pressurised furnaces. So my risk acceptance is somewhat higher than most!
    • Been needing a new clutch for a while, but holding off because of life tingz and adulting. But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799). Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them). Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
