Not sure about how hard the R33 one is to get to, but mate had a 300ZX which had to have the entire dashboard removed to get to it. Job ended up being about 100 dollars in parts and 700 in labour.
Just hope its easy to get to. If you can, take it out yourself and get it repaired/replaced, that way you save a heap of cash. You can still drive the car around without it for a while if you plug up the water lines on the firewall.
Red17
https://www.sau.com.au/forums/topic/24372-heater-core/#findComment-520497
yeah mines been dead for over a year :( just got a new core on order from japan through UAS! still waiting for that to come in, will post a walkthrough and some pics if you still wanna do it yourself!! heard it is easier that the Zeds to do!!
had the dash off for the respray, only hard part is getting it over the steering wheel, but you just take that off too!!!
https://www.sau.com.au/forums/topic/24372-heater-core/#findComment-520974
wrxetr, take the heater tank out and take it to a radiator repairer , if its coroded he maybe able to get a new core to match then he uses ur tank and puts the new core and its as good as new as for r+r heater tank i dont know how hard it is on the sky , u may have to have the dash out though to get to it , most cars u do .
https://www.sau.com.au/forums/topic/24372-heater-core/#findComment-521096
  Quote
Red17
Just wanna agree, a friend's 300 has this problem, he tried to remove the dash and apparently it is basically if not definetly impossible to remove it without breaking bits. And it will drive Are you positively annoyed friend? trying to take everything off. Hope the r33 dash isnt so bad. Ive installed a head unit in mine, it was simple so thats a good sign...
https://www.sau.com.au/forums/topic/24372-heater-core/#findComment-521536
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
