Not sure about how hard the R33 one is to get to, but mate had a 300ZX which had to have the entire dashboard removed to get to it. Job ended up being about 100 dollars in parts and 700 in labour.
Just hope its easy to get to. If you can, take it out yourself and get it repaired/replaced, that way you save a heap of cash. You can still drive the car around without it for a while if you plug up the water lines on the firewall.
Red17
https://www.sau.com.au/forums/topic/24372-heater-core/#findComment-520497
yeah mines been dead for over a year :( just got a new core on order from japan through UAS! still waiting for that to come in, will post a walkthrough and some pics if you still wanna do it yourself!! heard it is easier that the Zeds to do!!
had the dash off for the respray, only hard part is getting it over the steering wheel, but you just take that off too!!!
https://www.sau.com.au/forums/topic/24372-heater-core/#findComment-520974
wrxetr, take the heater tank out and take it to a radiator repairer , if its coroded he maybe able to get a new core to match then he uses ur tank and puts the new core and its as good as new as for r+r heater tank i dont know how hard it is on the sky , u may have to have the dash out though to get to it , most cars u do .
https://www.sau.com.au/forums/topic/24372-heater-core/#findComment-521096
Red17
Just wanna agree, a friend's 300 has this problem, he tried to remove the dash and apparently it is basically if not definetly impossible to remove it without breaking bits. And it will drive Are you positively annoyed friend? trying to take everything off. Hope the r33 dash isnt so bad. Ive installed a head unit in mine, it was simple so thats a good sign...
https://www.sau.com.au/forums/topic/24372-heater-core/#findComment-521536
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
