Item: 6 NGK spark plugs
Age: approx 1 yr old
Condition: used
Price: $20 each
To fit: Any turbo car
Contact: 0432 575 951
Comments: Postage available at your expense.
Item: Pair of MB Quart 6" front speakers
Age: approx 1-2 yrs old
Condition: used
Price: $50
To fit: Any car
Comments: Also have the MB Quart tweeters, but i do not have the crossover box. Postage available at your expense.
Item: Trust High Performance Air Filter
Age: 1-2 months old
Condition: used
Price: $80
Comments: Used only a few times, comes in the original box with all the bolts and pieces as well as the metal piece that holds on firmly while inducting air. Bolts straight on to your AFM without the need of any additional parts/pipes. Postage available at your expense.
As for those who know what damage these japanese kind of air filters can do, it's bang for your buck especially for R33/34 GTR. It bolts straight on to your AFM without need of any additional parts/pipes. Postage available at your expense.
Item: Set of R34 GTT rims with tyres.
Age: 1-2 yrs old
Condition: used
Price: $650 for the lot. $300 for the front 235/45/17 + 2 rims. $500 for the 255/40/17 + 2 rims. $200 for just the set of rims (no tyres).
To fit: R33/R34/Stagea/S15/V35
Comments: Gutter rash is very minor, only on 2 of the rims. Front tyres are Kenda kaiser 235/45/17 with 85% tread. Rears are Hankook K104 255/40/17 with 95% tread. One of the centre caps somehow got misplaced, but dw will find it asap.
Item: One 17" "Speedy" Cobalt with no tyre.
Age: 1-2 mnths old
Condition: used
Price: $80
To fit: Commodore/Falcon or along those lines.
Comments: http://www.speedywheels.com.au/alloy.htm & postage available at buyers expense.
Edited by Rashiq
https://www.sau.com.au/forums/topic/243740-a-small-garage-cleanout/
hahahaha ...
good luck with the Used regular spark plugs dude .... they only last , 60,000km at best in a good running motor
These are just regular plugs
and they retail for like $2.50 - $3 per plug so thats around $15- $18 for a set brand new ...
haha I thought this was a joke post.. "Tell him he's dreamin"
I thought the same
dayum i could get new irridium plugs for like $25
good luck with that
my humblest apologies to all - guess it just shows how pro i am...jks
well looks like i will have to claim back the "$20 spark plugs"..
the rest are for sale, except the spark plugs, of course :P
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
