I have a Nismo exhaust, but not a Weldina, that I cannot find a part number for on my car. It's advertised in the GT-R dress-up catalog that came with most of the GTR/V-Spec I catalogs, a single huge outlet with a 80mm pipe, and it's called a Spec-Pro. The one on my car has been chopped up kind of bad, the pipe from the cat to the tip had a muffler in line that was roughly cut out and pipe was welded in while it was on the car. Looks a bit ugly under there, and for a fairly significant show appearance I'm doing in the spring, I would like to fix it.
It's my preference to stay away from 3rd party exhausts at the moment, the car is being presented as essentially stock with a few Nismo pieces, but all 'Nissan'. I'll probably get into a Kakimoto down the line but for now, no. Nissan wants about US$1,200+ship to the US for stock exhaust components from the cat out to the tip. Yikes!
Anyway, I have the opportunity to buy a NIB Nismo exhaust of this type, kind of an off the shelf sitting in a warehouse boxed up by the part name (Spec-Pro Nismo Exhaust for BNR34) kind of purchase. The price is significantly cheaper than Nissan components but I can't get a square answer from the high-volume sellers if this item was sold only as a giant can tip or if the Spec-Pro 'Muffler' as the product is called includes the pipe coming from the cat too. Even japanese language searches on the product are not turning up an authoritative answer. Does anyone know for sure?
Here's the two pieces I appear to have (but chopped up), and have no reference to the stock parts. That muffler pipe is not a R34 stock version, correct? If not, I am starting to assume it is sold with as a set with the Spec-Pro.
This is what's on the can:
Edited by Danox
https://www.sau.com.au/forums/topic/243782-r34-nismo-spec-pro-muffler/
Just to prove how nice I am, I went into FAST for you - it lists a sports muffler option as part number KB0100, if that's of any use.
*smacks forehead* Didn't even think of fast for aftermarket upgrades...
That's definitely it. Resolved to B0100-AA325 and I found examples and pictures of it on the web and it is a match. Still can't seem to find any authoritative data on if it's packaged with both parts.
Thanks much!
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
