I need to replace some tired tie rod ends in the Series 2.
I have searched and found that that some were going to use R33 GTR ones, but the threads do not have any feadback beyond that-
- if they fitted up OK?
- if there were any problems with wheel alignment, tyre wear etc?
I can get the originals from Nissan Aust ($89 each in stock) or Burson's have aftermarket ones for under $30 each.
What have other people used as replacements?
The LH front one seems to go before the RH one. Is it just worth replacing both at the same time?
Are the R33GTR ones the same as the R33GTST ones?
Anyone with wheel alignment specs for a stock Stagea?
https://www.sau.com.au/forums/topic/243864-stagea-series-2-4wd-tie-rod-ends/
Thanks Chook,
Is this part number the same for the Series 2 Stagea? Can you have a look on FAST?
looks to be same, couple variations for different models, pm me your VIN and i can confirm.
  • 1 year later...
With S/H ones, be careful, I went thru a long battle til I got the correct one. If possible with new or used take the original with you.
OK I finally had the LH outer tie rod replaced on the Series 2 Stagea (1998 4WD).
This is what fits- Nissan genuine part No: 48520-23U26, cost was $87.
City Nissan Melbourne- parts centre Tel (03) 8383-8844.
The R33GTR aftermarket ones that were tried both did not fit! (Tried from Bursons and Repco).
Why is it that the LH outer always goes before the RH one?
Thats the rough end of the pineapple.LOL
Actually when I went thru this s#@*t afew years ago seconds at the wreckers cost $75.
Did they ever tell you if that part number was also compatible with R33 GTR at all? i need to replace mine, thats all and my local nissan dealership Quoted me $113.50ea
I think im going to ring the nissan melb number u have posted and ask directly, as my local dealership said they can get it out of melb over night anyway, so cut out the middle man?
Ring Nissan City Melbourne & give them your VIN no.- they will then give the right part number and a quote.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
