Hey all,
don't know if anyone has experienced this one before.... I've got a bleed valve on it to bring it up to about 10PSI but through the rev range it only hits to 10psi after it revs past 4000rpm. anything below that, its still at the stock 7psi. Can anyone help with any 'constructive' :D suggestions to fix this problem???
https://www.sau.com.au/forums/topic/24391-boost-issues/
Bleed valve is a cheap way to increase your boost, but not as reliable as Electronic Boost Controller one. solution perhaps is to get a proper electronic boost controller like Apex'i AVC-R or HKS EVC.
I have a bleed valve as well, still saving money to get an EBC.
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-520586
for $135 you can get the Turbo XS High Performance Boost Controller (HPBC)
it has 2 adjustments.
1 = increase boost
2 = reduce or eliminate wastegate creep.
the second adjustment is what makes the boost come on earlier and harder.
R33's standard boost is 7psi.
R32 is more like 9 or 10psi standard.
as mentioned, if you put a boost controller on, you need to use that INSTEAD of the standard boost solenoid...
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-522609
Originally posted by Hicks
Probably because the stock turbo cant make more than 7 pounds of boost below 4000 revs.
i doubt it as the r33 series 2 spools up real quick coz of the plastic comp wheel.
at the moment with my half complete project i can get 12psi boost at just under 2000rpm with lightened flywheel, adj cam gear and pfc tune.
Legend
I think you have your stock boost solenoid still connected in the line. Bleed valves are cheap and nasty, dont ever expect good boost control with them.
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-523152
Originally posted by legend
INASNT: me thinks I'm going to have to invest in an EBC...:) $$$
predator666: nope, got a greddy boost gauge :)
yes you better. I think my greddy profec b spec 2 also helps bring boost on early!! Only think with the spec 2 is that you have to *** around with it alot to get it to work the way you want
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-524336
yer.. with my profec it comes on at about full boost at about 3500rpm from what i remember.. not bad considering just S-AFC, zortst, cooler combo. it'll make a difference..
really depends on the bleed valve.. some are worse than others..
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-525744
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
