anyone else here of an R35GTR from sydney that has lunched an engine?
Apparently lost the top of a piston & has damaged the block & several rods.
If this is true, someone has blown, literally, a lot of money. I can see the Nissan official line now..."Sorry; no warranty on grey or personal imports...". Maybe the thread on 35 engines in this section will heat up even further with ideas! (LTS Jayce now keeping one sceptical eye on the 'For Sale' section, LOL)
https://www.sau.com.au/forums/topic/243931-r35-gtr/#findComment-4249948
I second that....
This does not bode well for Haltech's reputation...
I dunno. It depends on what they were doing at the time. If they were pushing the envelope, at least they now know where the limit is and what the motor doesn't like.
"Blowing stuff up and then pegging back the next one a notch" is probably a bit more popular a tuning method in America, given what I've seen with VQ35DE modification (it probably explains why Edison is considered their greatest inventor). A lot of manufacturers will stress test their mules and wait for something to break.
For example, Nismo found out that the conrod pins in a stock V35/Z33 VQ35DE could only handle around 7200RPM before they started to stretch, and they'd instantaneously snap at around 7800RPM. I can't see them figuring out those numbers without putting some pistons through some heads. It was the Americans who were probably the first to figure out that out the bottom end will only take around 300rwkW before the conrods snapped if you opted for non-natural aspiration, usually by aerating the side of the block.
Assuming they know why it failed, Haltech will be one of the few tuners that do. When it boils down to it, their GT-R is a test mule as well. Their car was never going to be sold on to a customer or be used as a daily driver.
From a regular person's perspective, it's better that they learn on their own car rather than a customer's. It's just unfortunate that's it's going to cost them a bucketload to get a new engine.
https://www.sau.com.au/forums/topic/243931-r35-gtr/#findComment-4253305
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
