I dunno. It depends on what they were doing at the time. If they were pushing the envelope, at least they now know where the limit is and what the motor doesn't like.
"Blowing stuff up and then pegging back the next one a notch" is probably a bit more popular a tuning method in America, given what I've seen with VQ35DE modification (it probably explains why Edison is considered their greatest inventor). A lot of manufacturers will stress test their mules and wait for something to break.
For example, Nismo found out that the conrod pins in a stock V35/Z33 VQ35DE could only handle around 7200RPM before they started to stretch, and they'd instantaneously snap at around 7800RPM. I can't see them figuring out those numbers without putting some pistons through some heads. It was the Americans who were probably the first to figure out that out the bottom end will only take around 300rwkW before the conrods snapped if you opted for non-natural aspiration, usually by aerating the side of the block.
Assuming they know why it failed, Haltech will be one of the few tuners that do. When it boils down to it, their GT-R is a test mule as well. Their car was never going to be sold on to a customer or be used as a daily driver.
From a regular person's perspective, it's better that they learn on their own car rather than a customer's. It's just unfortunate that's it's going to cost them a bucketload to get a new engine.
And I thought "I" had time on my hands... lol
I get what you're saying and agree completely though it'd be nice to know what they were doing and how they popped its cherry. For all we know it could've been failed factory component that caused it.
As for my above comment, if I was in the biz of tuning cars I can't say I'd want the first blown VQ38 chalked up against my name... Stress testing or not.
PICS!
https://www.sau.com.au/forums/topic/243931-r35-gtr/page/2/#findComment-4253335
How exactly do you figure that?
Scathing already posed that question more or less, read up and you can see his and my thoughts on the matter.
I'm not going to lose any sleep if you happen to disagree with me lol
oh n0s?! A disagreement on the intertubes?! emergency!
Still hanging out for some pics and detailed info plz :(
https://www.sau.com.au/forums/topic/243931-r35-gtr/page/2/#findComment-4255589
It was the haltech car. Pics were posted by a SAUNSW member about 5 hours after it happened. Old news now :D
lol, lies! :(
Well here is a (terrible) photo of the GT-R on the grass. The photo doesn't show it but the GT-R is smoking. Black oily smoke.
About 2 mins after this happened the session gets called off and it's mentioned that there could be oil on the track. I say there wasn't, other wise they cleaned it up pretty quick.
I'd say that it was something along the lines of oil leaking onto something hot and burning, but really I have no idea. For some reason they wanted to keep it quiet ;)
I'm sorry for the poor pic, but it was the best I could do from my phone's camera at that distance.
Personally I look at my photo and think I'm trying to start a conspiracy like bigfoot :(
https://www.sau.com.au/forums/topic/243931-r35-gtr/page/2/#findComment-4257121
anyone else here of an R35GTR from sydney that has lunched an engine?
Apparently lost the top of a piston & has damaged the block & several rods.
It damaged the block annnd SEVERAL RODS as well!? So thats the secret of the VR38DETT.. An extra rod, or is there more that didnt get damaged? :blink:
https://www.sau.com.au/forums/topic/243931-r35-gtr/page/2/#findComment-4274156
It damaged the block annnd SEVERAL RODS as well!? So thats the secret of the VR38DETT.. An extra rod, or is there more that didnt get damaged? :)
We finally learn to secret to the GTR's success, they run more than 1 rod in a 6 cylinder motor... Just wait til Porsche find out. I bet they secretly ran 6 rods in the car they used to set the time at the 'ring!!! :down:
oh PICS OR BAN!!
https://www.sau.com.au/forums/topic/243931-r35-gtr/page/2/#findComment-4275362
  • 4 weeks later...
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
