hey all been on here for awhile and car is finally getting to a point where i am happy thought i would post up some pics of the progress i have made with it because it is going to change in the next couple of weeks so this will be a sort of build up style thread.. well got the car 2 years ago with a few mods on it from japan and i have slowly done thing things like 5 stud upgrade, gauges in dash, seats the din setup, front mount kit, polished up all the covers and manifold,and got the wheels for it(i love the wheels)...
have also done some custom modifing like blocking off the stock oil cooler which worked incredably well and keeps temps down, and mounting the oil cooler on the front mount via custom brackets worked well and makes it much neater, i have done all the work to this car myself and although it has been along task it is finnaly starting to pay off and im enjoying the results...
the car is bumperless because its going to the paint shop this week to get a wonder kit fitted and i'm wanting to get a black roof line done in metallic black with silver pearl and a few touch ups as well like respraying the gaurds they are quite rooted due to having wide wheels on the front so ill post pics of the completed product at the end of the week ....
then 3 weeks from now its also getting a z32 ecu fitted and z32 airflow meter 480cc injectors nismo fuel reg with a re map so should be interesting to see how it goes with all those goodies chucked on it but again ill keep you updated and post up some dyno sheets once its done...
well enjoy these snaps the car is going to change alot in the next 3-4 weeks and ill make sure i keep this thread up to date and show ya the progress well enjoy.....
mods list is as follows
1988 nissan cefiro
rb25det series 2 motor + rb25 gearbox
trust tdo6-20 internal gate turbo
z32 ecu remapped (soon to have)
s15 injectors 480cc (soon to have)
z32 afm (soon to have)
nismo bolt on fuel reg (soon to have)
bosch 040 fuel pump
front mount kit
remote oil filter kit and cooler
3 inch straight through exhaust with twin tips
stainless pod filter
tomei timing belt
nismo copper mix single clutch
nismo 2 way lsd differential
rays engineering gram light pro rims 17x9 +38 and 17x8 +36
kei office coilovers
front and rear cusco strut braces
sabre gauges mounted in dash
blitz sbc id-3 boost controller
blitz r-vit information system
recaro sr reclinable seats + rails
no name deep dish steering wheel
wonder body kit and partial re-spray
basic stereo with pioneer speakers in factory postions and jvc headunit
if ya have any questions dont hesitate to ask i now have a wealth of knowlage with this car and engine oh and getting them through regency lol what a bitch that can be....
https://www.sau.com.au/forums/topic/243935-jbs-rb25-ceffy/
yeah no worries dude, will have pics up as soon as its done, probly wont be for a bit yet as im going to get the whole car resprayed in oooh cherry black, cant wait, haha sweet ride btw must have taken a fair while to polish up all those parts
https://www.sau.com.au/forums/topic/243935-jbs-rb25-ceffy/#findComment-4256184
yeah i started and then got someone to do it for me i have a whole new level of respect for metal polishers there job sucks. get my car back tomorrow so ill post sum pics up just got the body kit fitted and the stock color touched up in spots and got the roof line painted metallic black with a blue pearl in it . the z32 ecu allows me to retain vct on the inlet cam where as the rb20 ecu doesn't allow you to do it cause rb20's never came with variable cam timing gives you a bit of bottom end while the turbo ain't on boost...
https://www.sau.com.au/forums/topic/243935-jbs-rb25-ceffy/#findComment-4258951
cheers just spun up 243 rwkw at boost worx and got my number plates today lol (cefwepn)
Can I ask what the injector duty cycle was like? I was considering using those S15 injectors for my RB25/30 hybrid but I'm worried they won't be big enough.
Also, I'm going to be using the Z32 ECU and getting it remapped. How did you go with the loom? From what I've read it looks like there is only a few wires that need repinning at the ECU, then I guess it's just a matter of sorting out the plug for the body loom.
Edited by daisu
https://www.sau.com.au/forums/topic/243935-jbs-rb25-ceffy/#findComment-4317942
  • 1 month later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
