any of you guys experienced stalling once the SAFC is installed? i havent tuned it yet but set sensor to now set to 4 in 4 out as stated in the manual for a R33 GTST (HW-4). When the car is cold and and i try to accelerate, its like not pumping enough fuel and the car feels it going to stall? this happen straight away after the SAFC installed. i was thinking the A/F has been adjusted now? but i havent changed any settings besides the sensor type 4 in 4 out. I have already initilized the unit so now back to default settings.
Checked in:
Menu:
1: Monitor
2: Setting
3: Etc..
Selecting Setting ----> Dec. - Air --->
it reads:
Thr : **** %
Ne1 : 10.0 %
Ne2 : 10.0 %
Is this right? that Thr : **** % ?????
If one of you guys can just turn on your car and go into settings --> sensor check --> see if it is set like the above and get back to me would help me heaps.
and:
3: Etc.. ---->
Sensor Check --->
Reads:
In-1 : 1.02v
In-2 : 0.03v
Thrt : 0.475v
Is the voltage ok? Using a stock A/F sensor.
Checked all my wires, they seem fine:
Red Wire = Power
Green Wire = PRM Signal
Gray Wire = Throttle Signal
Brown & Black Wire = Ground (Brown closest to ECU)
Yellow Wire = One end Connected to A/F Senor (close to ECU)
White Wire = Other end Connected to A/F Sensor
I also have the Apexi turbo timer. When check the A/F on that unit during decelerating, it jumps from a steady 14.5 all the way to 20??? Is this right?
Car hasnt been boosted so running 7psi stock using a stock BOV .Waiting to get it boosted before tuning the SAFC..
Already checked www.apexi.com documents there are kind of hard to understand... :(
Cheers
https://www.sau.com.au/forums/topic/24395-configuring-apexis-s-afc-stalling/
does your a/f jump around on when u accelarate? when u back off its normal to jump around a bit .That throttle sensor is cool just means ur not using the dec feature ,which is bull shit anyway.Check that your lo throttle map is on 0% from 1k-8k if it is then triple check your wiring mainly your a/f signal.If its second hand then it could be faulty ,i bought a 2nd hand safc that just wouldnt let the car idle proply ,got another 1 hooked up the same and worked pefectly
Thanks for your help once again Bo0sT_JuNkY :( my a/f stays the same when i accelerate only jumps to like 20 (from the turbo timer) when decellerating. Just checked low and high trottle map all set to 0% from 1000 - 7000prm. Too cold and dark right now to check the wiring.. will do it first thing tomorrow..
Thanks once again dude..
btw:
Does your Dec. - Air -- reads
Thr : **** %
Ne1 : 10.0 %
Ne2 : 10.0 %
Is Thrt : 0.475v too low for throttle voltage?
THR is your throttle.. if you monitor the THR, when you squirt the accelerator it should show you how much you pressed it (e.g. 50% half to the floor, etc). Likewise "sensor check" should show the voltage for THR changing when you do that.
Sounds like you missed a line to the ECU ? if its reading **** it probably means it can't read the THR reading, and hence having problems.
I'd let u check all mine out but don't have my car atm..
for Dec-Air : from memory the "Thr" setting is the amount of throttle where the SAFC will start to compensate and try to stop stalling. i think i set mine to something very small like 2-3%. ie if you have less than 2% throttle pedal pushed down it will compansate.
the ne settings refer to the amount of extra fuel the SAFC will dump into the engine at that rpm to stop it stalling. i think mine are at about 4-5% for ne1 and 3% for ne2, bearing in mind that the settings on the fuel graph for low throttle are around -7% for those points
does that make sense??
without the Dec_air set up, my car stalls all the time when pulling up to lights/clutch in, worse +++ when the engine is cold.
try those settings and see how you go.
What does Ne1 and Ne2 actually mean on the Dec Air setting?
Edit: I know they mean +fuel, but what's the difference between the 2? And if it constantly adds in fuel at idle, wouldn't it be the same thing as setting the lowest throttle point higher?
im afraid of that :D . im 100% sure all the wiring is good, so on your safc it does read **** in the Dec. - Air -- Thrl:??
will recheck the cables again.... ohh noo.. thanks for your great help once again gord! :D
Thanks for your feedback and help Beeble. been great help. :D
Someoen should start designing a virtual SAFC website !.. heyy good idea i might create one so people can start playing with it online? as in take screen shots of the menu's and u can flick through it and stuff without actually doing it on your car as you dont wanna stuff it up..
I experimented with my Dec Air settings. They were set to **** 10% 10%, and I changed them to roughly 5% 5% 5% and now it seems to stall easier. I don't know if **** means the function is switched off entirely or if it means 0% (I didn't take note if the first step was 0.1% or 0.0%) but either way it was better the way it used to be. But not much coz it stalls either way.
I also took note of how much throttle was on percentage-wise when my foot was *just* touching it. It came up around 6-7%, so I think if you were going to set the Dec Air position to be 5% you may as well set it to 0% (or vice versa).
Hehe I just looked over what I wrote and it looks like I've been censored :D
lol JimX. Thanks for your info too dude.
have you got afm BOV?
From the Apexi SAFC Manual page 22, it reads:
When the Thr reads **** the deceleration parameter is not functional???? how can it be not functional? that i dont get.
Anyone else experience this too?
Yes, I have an a/m bov.
Hmm, so **** means it's been doing nothing all this time. I'll try 5% 10% 10% and see what happens. I think it needs to be a bit more than 5% extra fuel, because when I'm trying to stop it stalling myself, I need to put my foot on the throttle a little more than the 6-7% I quoted earlier. Maybe 15 or 20% then.
I get the feeling that all I'm going to accomplish is waste more fuel but keep stalling anyway :D
Thats soo weird JimX. Anyway i rewired the throttle wire once again , resetted my ECU, hooked the trottle position wire back in place and now in Dec. - Air -- Thrl NE1: 5% and NE2: 5%???
so the values have changed from 10% in NE1 & NE2 down to 5% and all i did was rewiring it.
kinda weird.. anyone experience this?
I tried 5% 15% 7% and it seemed better to begin with, but soon started stalling again. It's almost as if you can tune it to not stall, but the ECU's learning mode decides that stalling is better and starts stalling again.
Does anyone know if a PowerFC definitely fixes this or do you still need an extra idle controller (like the HKS one).
Pushead, I haven't written down the current settings yet (too lazy), but I've got the old ones after the first tune. The only difference between old and new are catering for a front-facing plenum and bigger front-mount intercooler. I wouldn't advise using these settings directly as a base level, except for maybe the Lo/Hi throttle settings. If you do I won't be responsible for blowing your engine up :P
Apexi S-AFC settings:
Lo: %
1000 0
2000 +3
3000 +5
4000 +1
5000 -4
6000 -2
7000 0
8000 0
Hi: %
1000 0
2000 +3
3000 0
4000 -8
5000 -13
6000 -9
7000 -2
8000 -2
Throttle position:
Lo: 45%
Hi: 46%
Dec.Air:
Thr: 5%
Ne 1: 15%
Ne 2: 7.5%
Oh, the car seems to be not stalling again. It's going through some phases, and I hope it settles on not stalling :) It's come close to stalling but didn't do it at all tonight. So I think the above Dec. Air settings are a good baseline to start with.
pushead dont copy other peoples safc settings.
also turn the dec air feature off, it has never worked properly on any car i have seen. Leave it on 0.
your car should have any problems is all the setting on the afc are 0, as it will be like the safc isent even there
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
