Vehicle/model:
1997 NISSAN SKYLINE ECR33 SERIES II GTS25t TYPE M
Kilometers:
87, XXX – Can provide papers (Private Import)
Transmission:
5 Speed manual
Engine:
RB25DET
Registration/ Road worthy Certificate:
Will supply RWC. Rego expires on the 12th of Feb 2009.
Will renew registration for new owner.
Brief Comments:
I personally Bought and Imported this car form Japan in 2005.The car had around 55,XXXks on it when imported. (Can supply papers)
I’m the only owner in Australia and was first registered under my name.
This car has been my baby for the past few years. I need to sell it as I'm looking at buying a House
and need a deposit.
Engine Hardware:
Tomei 1.5mm Head gasket, all new turbo/exhaust gaskets, Split Fire Coil Packs
SARD Adjustable Fuel pressure regulator, Custom Oil catch can,
Custom Front Mount intercooler and Piping (bar and plate)
Greddy Type S BOV, Turbotech manual turbo boost controller,
JPC High Flowed Turbo with HKS adjustable actuator. (http://www.jpc.com.au/)
Turbo back Apexi Dual N1 Exhaust system, 3’’ High Flow cat.
Walbro In tank Fuel Pump. APEXi Pod.
SAFC2 Tuned to make 225kw @ wheels with 1.1Bar boost. (Can provide dyno sheet) Tuned on 5th November 2008.
Drive train:
Exedy 9 puck button clutch
Brakes/suspension:
Front & rear adjustable Sway bars
Factory ABS
APEXi lowering springs
OEM 4 piston calipers @ front with Ferodo DS3000
OEM 2 piston Calipers @ rear with Ferodo DS2500
Wheels & Tyres:
18x9 & 18x9.5 Blitz Techno Speed Rims
YOKOHAMA 245/40/18
Bridgestone Grid II 265/40/18
Bodywork:
Full explosive Body kit - Atlantic White
Stealth spoiler (Lip)
Interior:
Alpine CD/PM3 player, Alpine Type S speakers (4), Coustic 4 channel Amp
Atlantic 2 channel Amp, Kicker 800watt RMS Sub, Custom boot installation.
R33 GTR Series 3 Front Driver & passenger seats. (Red inserts & stitching)
APEXi Boost gauge, SAFC2
Price: $17,500 With Supplied RWC & Registration payed for new owner.
If you have any questions Please call me on 0421 205 751
No swaps..
Regards,
Dush
Edited by Dush
https://www.sau.com.au/forums/topic/243953-ecr33-series-ii-gts25t-type-m-melb/
Thanks DjeMz for your input...
Yea I tried my best to keep her form not looking like all the other R33's you see out there..
Not in a hurry to sell this.. but If someone comes with the right price, I'll be sure to let it go...
This is a seriously nice car. I have driven it a couple of times and it has a good solid feel that a series II R33 should have.
I dunno why people would buy a stock one for 13k and then end up spending 10k on doing the basic mods and extras that this thing has.
In my opinion it is very good value for money at that price.
Edited by Starionturbo
Hey kim, Thanks for your positive comments towards the car. Greatly appreciated.
How is the Ceffiro going champ?
Just to clear things up. The car will be sold with RWC and I WIll pay rego for new owner if it expires.
If have to Will remove parts to lower the price @ buyers request.
Thanks for the PM's
was this on mt dande last sat morning?
if so, nice car, granny driver but
Nah champ it wasn't.. car don't see the road much as I dont have a license.. Only the late night trip to the car was here n there.. lol
I recently bought a Mines Tuned ECU/Rom form Japan
The ECU is using the VX-ROM - Got it installed and dyno tuned again.. Using the SAFC2 to fine tune the Rom - she made a strong 242kw @ 1.1bar of boost. Can provide Dyno papers.
Cheers,
DUSH.
Edited by Dush
  • 4 weeks later...
I just paid Rego on the car.
Also installed New FUSION 3 Ways 250watt and FUSION splits 350watt on the car as one of my rear speakers blew. So you pretty much have a new stereo system in the car.
  • 10 months later...
Lol i was just looking at this thread as mine has similar mods and seeing how much you sold it for as i'm nearly at the stage as well..
Wanting to get out of cars and get a 4wd and boat but i can definitely see myself missing my skyline as you do yours... sigh.
  • 1 year later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
