hit there i have an idea instead of turboing my na 33 gts-4, since these machines came out with the gtr driveline i was wondering if i could get a gtr block and head then biuld a motor up, i want to use the sump from my gts-4 to keep it awd but am afraid none of this is allowed in s.a and the car will need to be engineered, the engine will take a while to biuld as a lot of the parts are going to cost an arm and a leg(tomei and such) but i am hoping to chase at least 320-400kw from all of this. i will contact lmg to do the tuning anf fitment as they are great at this sort of stuff, can anyone recommend cams,cranks and injectors casically any good brand and part to run in this engine.
cheers... michael
https://www.sau.com.au/forums/topic/243968-creating-a-monster/
  • Replies 46
or
you could simply rebuild your current motor
ie
Forged rods & pistons
head gasket to suit
bearings
crank work
studs
cams
feul setup
injectors
pump
feul reg
then obviously the turbo setup
something like the GT35/40
or you could put an rb26 setup.....
all depends
well your sump is a GTR one
im rebuilding my engine at the moment mate with 50thou pistons and the bottom end is GTR where it meets the sump and RWD where it meets the head to suit the rb25 head......basically and honestly a gts-4 is a mongrel to work with in parts. If you were to buy a rb26dett you would need to look into a bolt in job as i know that
DIMENSIONS (L x W x H) (mm). NOTE* this is manual, auto engines have different dimensions
rb25de:2wd 845x595x680
rb25de:4wd 845x595x690
rb26dett: 870x656x675
there may need to be some work with the engine mounts but a rb26dett will be able to sit snug in height, the placement of turbos and such are going to probity be placed far away from stock engine bays specs and you may find that your going to have to build a rb26 thats gona look different in the engine bay. Also part wise you will be able to find some GREAT parts just as cheap as a gts-4 part and make 400KW for half the price with EZZEEEEEE :banana:
even i know that 320-400kw out of n/a engine is just stupidity and not even possible.
even if u do get a 2.8l stroker kit and forged pistons/con rods and bigger cams
most defiantly
2.8l stroker kit and CUSTOM forged pistons(ones with unique crowns that are higher than factory/conrods and bigger cams, Custom exhaust system from extractors to tip, 6 cylinder DCOE 52/48mm (some ridiculous injectors to make requirements of air to fuel Ratio, porting the head, increasing the heads face to an overall compression ratio to 11:1, nitrous-oxide SYSTEM (correct injectors to support this again ..... more matching!!!), MSD ignition modules, ECU ....... other bits and bats yeah i reckon 300kw N/A is possible with the money and right parts
NOT WORTH IT!!!! no even for show. it will just cost so much in fuel and insurance and stuff. MissR34 + 1 with the stupidity
Edited by central coast person
cheers... michael
umm .........
most defiantly
its not na if you use nos, NOS is a type of forced induction
cheers... michael
mick is this your first car and are you on your P's?
that sort of power is HUGE on the street, if you havent been in a car with that sort of power, i suggest you start talking to people that do and get them to take you for a spin, its bloooody quick. Its very easy to type numbers but honestly you dont need much more than 300kw's for the street, thats plenty.
Have a read around for r33 gtst, see what people have done to get certain power levels, everything engine wise you learn from the rb25det's can be used for your engine.
Also if you want around the 400kw mark, whilst your gearbox internally is the same as a gtr your rear diff definately isnt. They run the smaller axles (same as the gts skylines) and with that sort of power you'll definately start braking drivetrain parts.
people debate if nitrous-oxide is forced and its not forced induction :D
just mixes in with the fuel. Just another liquid added to the car which is why i include its input to kW's. Then again i get what your saying and it isnt seen as forced induction in racing but drives are to state yes or no to there cars if there run on nitrous-oxide because its got its own category just for that type of ........ 'enhancement'. Who knows what natural not even plain old ron98 is :cheers:
agreed with the amount of kW you want for a street car????
if so a 400Kw street car is seen as a work of art getting on the road. Also difficult to drive just because all the parts are going to have to be fairly heavy duty with that power and not street friendly. if your after a street car look how far you can go at making it a desired car with power and comfort for driving because if you make a mistake with the power you most likely wont make money back selling the car or parts to quieten down your car.
thanks for the replies, gtfour a mate at work has a xr6 that made 495+kw at the wheels loosing traction on dyno and is street legal(it can make up to 600rwkatw if the box was done), its quick, i am not after that sort of figure and your right 300kw is what i want to start of with this isn't my first car ive owned a few and am on my p's, as far as i know s.a has no laws bout p platers and hi powered cars as of yet.
money wise is not an option as i can work 12 hour days 13 days thats easy(sort of hard being an apprentice working in the mines). i am also thinking of building the motor up then selling my skyline then buying a gts-t and putting it in, as ive been told that a single turbo engine can make more power than twin in some cases. dont know bout that??.
anyway i will probebly buy a engine then go from there.
cheers... michael
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
