realistically this thread should have been originally posted in the forced induction thread me thinks.
or maybe even again, not posted at all and maybe the dude that posted this thread should just go see a mechanic or engine builder and sit down with them and talk to them about it. that way they will get a much better idea of what is involved as well as costs involved.
  • Replies 46
OK, to start with I hope the above figure is a turbo figure cause you will never see that from an n/a motor, I doubt you would see that with nitrous and I have a 26/30 n/a setup in my 31.
Of course it will be a turbo motor lol, sorry should of said that. Probably get it built then put twin GTRS's on it and that should bump up the power to make over 400. Gonna be costly tho :P
I remember reading quite some time ago that the atessa AWD system in the R33 GTS4's is *NOT* the same as that in a GTR... from what I remember reading it was slightly more simplistic in nature... ie. didn't have the full feature set that the GTR's did (sensors and what not). I may be wrong, but I do remember reading a fairly in depth article on it. In contrast, I know the R32 GTS4's is the same as the 32 GTR's...
gts-4, gtr have exact same system no doubt.
bottom line for this thread wont be giving you answers about turbo like a turbo forum, anyone trying to make 300kw+ for a non turbo is going to have to spend the stupidest amount of money on the car and yes making it a gts-t would help if you want to make it a bit of a drifter car but maybe moving the thread would save you the hassle rather than deleting it because you already know its going to have to be engineered if you use any other skyline engine other than a gts-4 one or do the internals either way let the turbo people wave there turbo magic on you.
ok i seeeeeeeeeee. :D
big turbo fixes stuff haha, still you mentioned drift and i doubt the engine will hold up with all that pressure. The money will need to be poured in, in the long run.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
