My tip is dont be stingy. I had the worst tyres on my stock rims, and I lost it soooo many times in the wet, just from turning a corner without acceloration. I now have tyres worth over $250 each and they are a HUGE improvement. The car will now corner faster then what I'm prepared to take it, even side stepping the clutch in the semi-wet is difficult!!
I wouldnt reccomend the Sumitomos I have on my car, purely because of the price. However, if you have the money, go for it!! Otherwise, go for the most expensive you can afford, without going over the top like I did. So many people forget how important tyres are, they are what keep you on the road!!
Good luck!! :banana:
https://www.sau.com.au/forums/topic/243969-new-tyress/#findComment-4249972
I love the Sumitomos, and only paid just over $800 including a wheel allighment because of a trade price discount, however it doesnt break traction like the old ones :banana: And they're too expensive to burn! Never again :) But they are fantastic for the main reason why I bought them
https://www.sau.com.au/forums/topic/243969-new-tyress/#findComment-4249985
NA :banana: but its so prruuddyy so i could never part with it haha
i was thinking about putting a turbo on, but my engine is like amazing and ive never had a problem with it so i dont wanna thrash it and ruin it :)
https://www.sau.com.au/forums/topic/243969-new-tyress/#findComment-4250043
I was thinking the same thing, but costs too much to convert. Play around with your car for a bit, and when you get bored upgrade!!
At least you dont need to worry about boost kicking in when its wet and sending you out of control!
And I wont be the only NA on cruises :banana:
https://www.sau.com.au/forums/topic/243969-new-tyress/#findComment-4250055
Best tyres i used on my 33 last time was the Bridgestone Potenza G3's... Man those f**king tyres stick to the road even when its really wet! I only started sliding around when theres only like 50% tread left..
They don't come cheap though.. if I have not mistaken I got a set for about $1400+wheel alignment 2 1/2 years ago...
https://www.sau.com.au/forums/topic/243969-new-tyress/#findComment-4250081
Federal 595SS's are good tyres for a good price, I pay retail of under $200 a corner from a local tyre joint. Oh and they take quite a hammering too :cheers:
I had these on my old 33 a couple years back..
I have the 595 RS on this car, very nice but cost around double the 595 SS.
https://www.sau.com.au/forums/topic/243969-new-tyress/#findComment-4250829
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
