Looking to sell my rims to buy others that arnt quite as wide as these arnt needed on a gts4.
They are ADVAN 17's.. Front are 235 wide, rears are 255 wide. Tyres are Nankane with about 80 ~ 90% tread.
center caps missing off 3 rims, and a few scratches around edges (can kinda see in pic).
Sorry no more pics.
I dont know what i sould be asking?? I have been told around $8-900 with tyres. I would prefer a swap as i need wheels to move.
https://www.sau.com.au/forums/topic/24397-super-advan-racing-rims-17s/
Not interested in selling the wheel nuts, are u??
I've got 12 wheel nuts only, I need another 12.
I've opted for am stuff and powdercoated them black, but wouldn't mind std super advan racing nuts.
Danny.
am=after market, I bought the allen key type and one set of security nuts and powdercoated them black, they look OK, but I'll keep my eye out for the std advan ones as well.
I have had heaps of interest since last night already. I am not going to sell any nuts/centre caps etc. seperatly. i would be interested in swapping my Advan's for stock r33 or r32gtr rims + cash. I cant sell my rims outright as I need wheels to get around. I am interested in any 5 spoke rims for swap.
I would rather not ship the advans anwhere.. ie. sell to any1 between gold and sunshine coast. Unless you are willing to travel.
thanks...
Due to some insight I am now looking for $1600 for the ADVAN's plus tyres.
If I choose to swap for another type of rim I will be looking for something like the following + tyres.
http://www.liveupdater.com/magandturbo/Ima...brary/raptc.jpg
But if you have any rims to swap email me with the pics so i can take a look.
I will get some more pics up asap.
are they scratch free and have all centre caps? if not good luck.
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
