veilside 17" mags f/s
selling veilside 17" mags backs are 8" wide and fronts are 7.5" 235/45/17 bridgestone on back and folcons on fornt( fronts will be change to better second hand rubber before sale) still leagal rubber a few scratchs on rims and i have removed the nut in the centre cap a cheap upgrade form standard
rare wheels in australia
pics
$1,000 ono (will swap standard wheels as part payment)
Attachment: r33_25.jpg
This has been downloaded 101 time(s).
man those wheels are a bit scrached my wheels have no were nere that many scraches, good luck with the sale though
free plug bye my wheels someone they are in "GOOD" conition.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
