Just bought a project bike, and am trying to figure out paint scheme. Satin/matte black is a definite, but not sure what I'm going to do with the frame, and how far to go in general. I've looked through heaps of streetfighter (this style of bike) pictures, but most are horrible overboard Euro things which make the tail on this thing look conservative. Alien looking headlights on almost every one of them... horrible. Anyway... photoshop to the rescue.
Looking at a couple of options with this pic.
1. Satin black frame, swingarm, undertray (the bottom silver bit under the engine) and wheels - delete little bar under the swingarm (torque arm for rear calliper if you care). Change forks to light gold (as they are on my bike, washed out light gold compared to the more bronze colour in this picture.
2. Satin black frame, swingarm, delete undertray, same deal with forks.
3. f**kit, do what you want - theme is similar to donor pic, tough, hard dark, cheap, simple.
Any help much appreciated guys.
slip.
https://www.sau.com.au/forums/topic/243983-motorbike-photoshop-request/
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
