Hello,
I have a query about a noise in 3rd and 4th gear (it may be in all gears, but isnt notable) - after said gears are engaged and letting the clutch out and applying throttle at the same time, a groan at the length of about a second is heard. Its a deep groan, and no vibration is aparent through the stick or pedal so I dont think its the clutch. I have been told that these gearboxes are just noisy, but I'd like more opinions.
There's a slight sound when the car is idling in nuetral, and I suspect the thrust bearing - but not sure if its related.
Your thoughts and expert opinions please...
Michael.
https://www.sau.com.au/forums/topic/244000-r34-gt-t-gearbox-noise/
Hello,
Michael.
If it is the Thrust Bearing, when you clutch in, the sound goes away. Clutch out, whirring sound comes back. The R34 GTT doesn't have noisy gearboxes. Wait till you hear the Getrags :banana:
If it is the Thrust Bearing, when you clutch in, the sound goes away. Clutch out, whirring sound comes back. The R34 GTT doesn't have noisy gearboxes. Wait till you hear the Getrags :cheers:
I have this on my car. No groaning, but a constant "sshhhhh" whirring noise when I clutch out in neutral.
Is this something I should be concerned about?
If it is the Thrust Bearing, when you clutch in, the sound goes away. Clutch out, whirring sound comes back. The R34 GTT doesn't have noisy gearboxes. Wait till you hear the Getrags :ninja:
+1 getrag plug light flywheel and twin plate clutch is awful.
OK,
But I'm just talking about a standard gearbox and clutch here...
I assume from the veiwed/posts ratio that no-one has experienced this sound?
Perhaps this car may be a risky purchase.
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
