R33 Type M front bar plastic welding (cut middle out)
Hey people, a question for those of you who have modified a type m front bar for a FMIC -
who did the plastic welding for you (to fix the sides of the bar in the middle cut-out) and what did it cost? I'm in the inner east if that helps, but any pricing info is good...
and, how much would i look at to get the front bar resprayed after?
Cheers ronin
Im from Western Sydney and looking at getting the above done when I get my 400R kit painted/fitted.
Got a quote of $500 for....
* Cut number plate section and patch side
* Mesh bottom of front bar
* Re-align FMIC (its about 1 inch to the left)
* Fit UAS air filter box over my HKS Pod
* Connect ducting from that box down to the front bar
* Respray entire front M-Spec bar.
pushead, yep thats the one :P
benm that sounds good, keep the replies coming - if anyone has a specific place they've used to plastic weld the bugger in melb that would be even better :)
my front bar is *cough* a bit worse for wear from driveway approaches (particularly my own drive - the old man has a 911 and every morning i hear is scraping... oh the pain!). i'm going to get the whole bar redone, at the same time get a stealth wing swapped over :D
haha... thats not a bad idea, but i just can't be bothered... i haven't as yet cracked the current front bar, but it has no paint on the bottom :D
Means i can't lower it either :D for the time being
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
