Hey all,
I have a restriction on my air flow in my R32 gts-t .. I'm currently in the process of troubleshooting to work out which part of my intake / exhaust is causing the problem, and i was wondering if anyone could offer some good knowledge to see if i'm on the right track.
Here is my car's setup.
rb20det
apexi pod filter
greddy spec-m fmic
rb25 turbo
just jap split dump
x-force hi-flow cat (since been made even more higher flowing :ninja: )
greddy pe2 cat-back
gtr fuel pump
nistune ecu
manual boost controller
Here are my assumptions .. please correct me if i'm wrong:
- The dyno sheet shows a quite steep decline in horsepower once revs reach over 6000rpm. This indicates i have a restriction?
- The sheet also shows that boost is maintained flat on 14psi all the way to the end of my revs. This means the restriction is not on the intake side?
- The Greddy cat-back wouldn't be restrictive would it?
- Could the turbo itself be the restriction?
- Is it possible the wastegate pipe on the split dump is too small?
any advice / suggestions are highly appreciated. Unfortunately my budget is quite small, so i want to minimise trips to the dyno.
Thanks!
https://www.sau.com.au/forums/topic/244091-restricted-flow/
  • Replies 45
Posted Images
Post the dyno sheet, preferably with afr's..
I will address a couple of your points: it won't have anything to do with the wastegate hole in the dump being too small, if it was too small you would see massive overboosting.
I also fail to see how an RB25 turbo could choke an RB20.
It possibly could be the catback..
It could possibly be on the intake side as boost pressure is really just a measurement of restriction (i.e. you could have a restriction which results in the pressure you're seeing but flow would be limited).
https://www.sau.com.au/forums/topic/244091-restricted-flow/#findComment-4251510
I'll post sheets tonight once i get home from work.
I didn't think it'd be the turbo, but it is quite noisy.
My theory on the intake is that if the flow was restricted, then not enough air would be able to get into the system to maintain the boost.. but point taken. i will investigate that side of the system also. Perhaps a larger filter is in order.
I hope it's not the cat-back.. sounds really nice and cost a pretty penny. :D
Thanks for feedback
https://www.sau.com.au/forums/topic/244091-restricted-flow/#findComment-4251522
Flow and boost pressure are two completely different things. Pressure is a function of flow (velocity/force) by area. Yes turbos will flow more air at higher pressures (to a point), but what you're measuring on the engine is the turbos ability to create pressure against something (closed valves etc). If there was no restriction, you wouldn't be able to make above atmospheric pressure as the air would just flow straight through.
This is also why by removing intake restrictions (bigger pipes, better flowing head etc) people can make the same power on less boost.. there's obviously always tradeoffs though :D
https://www.sau.com.au/forums/topic/244091-restricted-flow/#findComment-4251535
has your fuel filter been replaced lately /at all . has very similar symptoms although had no dyno sheet as proof but you could just tell by driving . pulled old one off and struggled to blow through it at all . put a new one on and it went 8 million times faster . maybe not 8 million . but atleast 6 million times faster . yeah seeing your A/F ratios would help a lot
https://www.sau.com.au/forums/topic/244091-restricted-flow/#findComment-4251541
got it dyno'd twice (once an initial tune with the new ecu and again when i "hi-flowed" my cat and upped the boost a little) .. Both showed the same symptom of the restriction.
On the first initial tune the A/F ratio was bang on 12:1 for the whole rev range..
the second (which i will post tonight) is less consistent, but still in a good range.
i believe the filter was replaced with my 100,000k service (which was only 8000k's ago)
Edited by Wogan
https://www.sau.com.au/forums/topic/244091-restricted-flow/#findComment-4251560
go to your local exhaust shop or shop of some sort who has thin walled pipe.. ask them for 10cm's of 3inch pipe.. than go buy 2 3inch hose clamps.. go home and chop your standard intake pipe in half and fit the pipe in and clamp it back up in position.. have a search there is a thread on here somewhere.. i think its called $5 intake pipe mod
Edited by Cartman
https://www.sau.com.au/forums/topic/244091-restricted-flow/#findComment-4251924
Dyno Sheets:
22nd Sept 08:
24th Oct 08:
I don't really see that you have a problem (other than running a stock turbo at 14psi). 240hp looks pretty good for your setup. Can't quite see the point in trying to wind it up past 7000 rev/min.
https://www.sau.com.au/forums/topic/244091-restricted-flow/#findComment-4252979
Just Jap dump pipe is probably the culprit. Peice of crap.
Why? we have already discussed this. Would be nice to substantiate what you are saying.
The boost takes a bit to come on, you havn't got a boost leak have you?
Boost seems to be hitting about 500rpm later than my RB20 setup was and that wasn't even tuned.. 240rwhp is about on the money though. I would suggest that maybe 14psi isn't really doing anything other than pushing hot air.. here's my RB20 sheet:
Red line was where we we tried to run 14psi but it pinged so dropped it back to 12 (as I wasn't tuning it at that point in time).
https://www.sau.com.au/forums/topic/244091-restricted-flow/#findComment-4253765
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
