Im really keen on giving it a shot but not in my car, so I want to by something under 2grand and head out to Mallala for a practice.
Can someone here tell me whats involved? Costs? Car reqirements, licences etc?
Thanks!
https://www.sau.com.au/forums/topic/244095-so-if-i-want-to-drift-one-day/
  • Replies 43
Posted Images
Of course, tow the car out there, and ensure the vehicle towing is in road worthy condition :laugh:
... or you can do what the NS boys do, and drive the car out there with front bumper missing, fmic in-ya-face, and then whinge about how the cops pulled you into a defect station and defected you :ninja:
Edited by RubyRS4
Haha wow. Yeah wont be doing this
As for costs and requirements.
A normal prac day is about $125 last time I went out.
$10 at the gate
$90 to go on the track (or it may be $80 I can't remember :laugh:)
$25 for a one-day CAMS licence
Then theres a full tank of petty, tyres and whatever else you might chew through.
I used to budget about $250-$300 each prac, as I'd just get cheap as possible second hand tyres for the back from the various tyre places I've worked at over the years :(
I've never towed my car out, just make sure your car is presentable (or drive a JZX100, the coppers waved me through last prac in my 100, they probably thought I was someones parent in a Camry going out there to watch :ninja:)
Edited by AndrewJZX100
on the contrary, ive been one of the few cars that were defected in the blitz police were doing at mallala for a bit there, i was defected for my cracked indicator lense. most of the real ghetto cars are trailered out there.
Saw a stag sporting this FMIC IN YA FACE look driving in Norwood on sunday. Wasnt me and wont go naming any names... Whos gonna guess who it was? up for grabs is this ziplock bag full of... AIR!
AE86 aka tureno if you can find one that cheap
:ninja: yeah good luck with that.
Go the 31 if you just wanna go out and thrash something. Take your 34 out there if you want to learn more about the car/driving in general. Once you get over the fear of bending a good car its much more fun.
agree with those that said to get a KE of some sort or your good old 31! Then budget for tow/trailor, entry, get some 2nd hand tyres..
Ive just picked myself up a KE35 for $300 and will doing a few basic mods (welded diff, stiffer springs) and taking it out to drift prac next early next year!
Eventually tho id love to go to something like an S13.. but all depends how I go.
    • (Rb25det intake manifold) I’m having a hell of a time trying to find the full part or part number of this coolant hardline so far I was given these (Below) but they aren’t what I’m looking for and was told it’s the IAR or aac valve but that doesn’t seem to be it either. If someone could point me in the right direction it’d be greatly appreciated. Or if anyone has it for sale that’d be great too. I have recently purchased a greddy manifold and I can’t seem to find my old one to pull it off.  (Front Heater Return / Water Pipe (under intake): Primary part: 14053‑21U10 (front return pipe assembly for R33/R34 RB25DET) Alternative listing: 14053‑21U00 (same pipe, sometimes interchangeably referenced)   Heater Feed Pipe: Listed as 14075‑04U00 or feed-related variant 14053‑AG500)
    • This sounds cool. But, as per usual, anything really complicated like that, that I take on, constitutes a steep learning curve that I never actually "learn". I just get it working, install it and start using it. Then, when it breaks a few months later, I've got no memory of what I did, how I did it, or even the bloody IP address I gave it. I'm having more or less exactly that problem right now. My Proxmox machine was discovered to be non-responsive, and the VMs on it were ditto. Power cycle it to a stream of loud Dell beep codes - which was unpopular at midnight, I can tell you. Move it to the lounge room so I can HDMI it to the TV for a screen, see the boot messages complaining about the /PVE/data having all sorts of LVM problems, saying it needs to be fixed manually. And I'm like....great. How am I going to work out what I need to do? At least it wasn't the stupid Silicon Power SSD shat itself. Mental note for all readers - DO NOT BUY SP SSDS! They are shit. I have had one take out an entire VM setup already, and this one could have done the same. Maybe it actually has. Cheap Chinesium shitbaskets. I won't cheap out again, even on play projects with no budget. Because my time budget having to fix shit is worth far more than the cost of proper parts.
    • I do typically agree. These days even the screens most people use have more of a boot time than the main device. However, I've seen an interesting use of the RPi in vehicle, however it involves effectively building your own OS and MBR, as then it boots up exceptionally quickly, as you don't have everything needing to start up, and you can then also run it up as an RTOS, while still having more compute than an Android can give for things like display, and processing. A very huge task that would be though for Duncan, I'm not sure that's his skill set (or Arduino programming and wiring) ha ha. If end goal is definitely just water cooling, Arduino would be the simpler setup especially for a rookie. If he wants extra display stuff though, bashing some code in Python on an RPi may be the better result for both systems.   Unfortunately the new device I'm building at work which runs a display, is too slow of a display for dashboard style purposes. More extreme low power, update only a couple of times a day type system
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
