hey guys basically, the head gasket is blown at the 5th cylinder .. compression is all good across the other 5, just 6th one is a little bit low .. still pulls n drives very hard .. water temps dont go up,
how ever yesterday i was driving it home the oil temps were getting close to 150 degrees, so i was going to pull over, before i pulled over the car stalls on me and now it never starts again. Even though the car has a blown head gasket i don't see a reason for it not to start ?
i change the spark plugs, put jumper leads on it as starting it without another battery support causes the battery to die. When i turn the car to accessories i can hear the fuel pump prime, and i just start it, it clicks and clicks and clicks and clicks but nothing happens. Any suggestions ?
https://www.sau.com.au/forums/topic/244109-gtr-wont-crank-over/
That is VERY high oil temps 0_0
So it won't crank over at all? You just get the start motor solenoid click? If so then you have to start from there and see if the starter motor is seized and if you can confirm the starter motor is good then you might want to get a compression and leak down test. Sounds like some bad stuff going on inside that RB26.
If it does crank but won't start then it's more likely that the excessive engine heat has caused a sensor to fail.
If it's clicking a lot then it sounds like it's trying to engage the starter but doesn't have enough voltage or the starter is damaged. You mention the battery can't start the car so the issue could be electrical and starter related. Check all your fuses then try and get a proven starter. Also need more info on whether the car cranks at all or just click click clicks.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
