R32 Gts-t - 256hp And Only Been In Aus For 6 Months!
I'll stick with the plastic containers, as stated by others, as it's where the old oil goes, I then just drop them off at SuperCheap, who apparently recycle it, or something.... I believe this makes Captain Planet not so angry with me for owning a infernal combustion engine, although he is still pretty pissed at me for using old engine oil to stabilise dirt pads in old workshop and factory yard hard stands in the pre 1980's There was nothing better than some old engine oil to strengthen and waterproof a dirt/gravel patch pad back then, and the rainbows that flowed off the pad and down the storm water drains when it rained was very pretty looking, I believe that practice is frowned upon nowadays 🤔
Some good points there @joshuaho96 I think I just looked at the box and the tap and started thinking of how much cleaner my changes could be. 🤩 I mean, I could always just use a funnel... Seems like thats the case here also.
By Robzilla32 · Posted
You may need two of these unless they are still in place: https://www.kudosmotorsports.com/catalog/rear-seat-cushion-lower-anchor-assembly-suit-nissan-skyline-p-2091.html -
These are sold all the time at Walmart and like others have said the angle is "more eco friendly". It is slightly cheaper. Oil-contaminated plastics cannot be recycled so less of it is better, but you need a whole bunch of extra stuff to handle this. You need probably one clean 5 quart oil jug you set aside to use as an intermediate holding tank. You need your local hazmat to return your oil catch pan AND you need to make sure whatever oil catch pan you use can hold engine oil without any risk of leaking during transport. Or you have dedicated used engine oil containers that your local curbside recycling will drain and return. Personally I have stuck to just buying 5 quart bottles because this is just too much mess to be worth the hassle.
