I imported my 32, and as usual the aircon condensor has been removed and degassed. i think it had the old gas in it.
does anyone know if i can take it anywhere to get it regassed or do i need to find someone who has the old gas?
a place in the western suburbs would be good. thanks for the help :ninja::laugh:
https://www.sau.com.au/forums/topic/244119-import-air-con/
Yeah in compliance, they will remove the gas due to some heritage law in Australia. They should re-gas it, though?
I know Profix regas air-cons! It doesn't need the 'old' gas, it just needs to be re-gassed with whatever the workshops use.
Costs about $149 from memory.
https://www.sau.com.au/forums/topic/244119-import-air-con/#findComment-4251391
Just get it re gassed, depending how far you want to get into it will depend how much u want to spend. Just get it gassed and see if it stays working, because there is no point replacing the receiver drier if you leak gas out a seal or a rubber pipe and need to get that fixed.
https://www.sau.com.au/forums/topic/244119-import-air-con/#findComment-4251484
Speaking of air cons, anyone know a place that repairs dodgy air mix door/actuators? Mines short circuited and requires a replacement
-D
https://www.sau.com.au/forums/topic/244119-import-air-con/#findComment-4251494
adelaide car care on marion road regas for less then $100 bux
i got mine done there but found out after that the air con motor had shat itself :)
couldnt find that place :D ended up taking it to isaacs auto electricians on brighton road, had to get some valves put in (as it was missing them) and regassed and serviced. works real good now tho! cold as!
https://www.sau.com.au/forums/topic/244119-import-air-con/#findComment-4254561
Does any1 know about the sensors linked to the aircon? I've had an auto electrition look at it and they couldn't fix they said possibly sensors behind??? Any ideas????
i know the locations of 3 sensors;
One is inside the centre unit, to the right of the ashtray (where there is a small air grille cutout)... thats the interior air temp sensor
then theres one on the top of the dashboard, its a black plastic shiny square on the passenger side near where the dash meets the window... that one is the sun load sensor/sunlight sensor
then theres another one in the front bumper section which is the external air temp sensor...
think there are a couple other sensors (one for the temp of the compressed gas at least) but I wouldnt have a clue where to look
If these guys are any good at fixing aircon's, I might have to take mine there... my PBR actuator is reporting a short circuit ;\
-D
https://www.sau.com.au/forums/topic/244119-import-air-con/#findComment-4255017
-D
But i've had everything looked at the fan works but no cold air comes out??
https://www.sau.com.au/forums/topic/244119-import-air-con/#findComment-4255031
ok what u need to do is run the diagnostics for the climate control... theres a guide here somehwere
basically you hold down the 'off' button of the CC unit as soon as you turn the ignition on... after 4-5 seconds it'll start up in diagnostic mode
you can then use the up and down arrows to navigate thru the options... you'll need to read the guide to interpret them, its your best bet of figuring out whats going wrong
if your fan works it could either be a compressor not working/no gas in compressor, or a stuck hot/cold mix door.... or a bunch of other stuff .... do a search on the r32 climate control and you'll find the diagnostic thread.... mine reports a shorted PBR actuator (controls the hot/cold mix coming into the car)
-D
https://www.sau.com.au/forums/topic/244119-import-air-con/#findComment-4255178
hey mate. if it is on r12, which is the scew type service port fittings then, you need to get it retro fitted to the new gas. the old gas is no longer sold as it not ozone friendly. the reciever drier will need to be replaced as it has been exposed to the atmosphere, and the oil changed to a R134a gas type (like ester oil) it's a massive fine if anyone is caught incorrectly gas vehicles or hasn't got a licience to do so. it costs me $100 a year for my licience so i can regas vehicles. if i was you i'd get it done properly just so the a/c doesn't completely sh*t it's self and cost you a fortune. that's my 2c.
https://www.sau.com.au/forums/topic/244119-import-air-con/#findComment-4255181
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
