  • Replies 75
Repco still said $117, called aussie auto's and they said $84.95 and conventry said they would match it. So for all the qld people check out aussie auto's for your EL o2 sensor. Hope this saves a lot of qld people a fair bit of work!!
Cheers
Jayson
guys save urself the hassle and buy one at petraject in melbourne, they sell you it with the corect connector and theyre reasonably priced, i bought one for about 120... its awesome, better fuel economy and no black smoke out of exhaust anymore, no running fat, get a new one or ull be up to buy a new one again soon with a second hand one...
ahhh ill go downstairs and look the addy for ya...!! they come with teh connector, just plug straight in... very easy... all my problems were solved after that... very nice ppl too....ahh ok sorry its petroject.... mate im not sure which addy it is, but ill give u their number and u can call em up, its 9873 7006.... and sorry again, it wasnt 120, it was 90 dollars for mine, but that was an r32 one... good news for u ey
I slapped my RB20DET in to the O2 Diag mode and drove around a little just to see what it did.
On cruising and quite a pit of part throttle it flicks rich lean rich lean, it also does the same on idle except some times it would stay on rich, i would notice the car would then pop on idle.
But yer it does appear that the O2 is still in closed loop mode even when boost is only just starting to build so I guess it could off boost balls and even feel a little more gutsy when boost is starting to build.
Any one thought of using a Skyline oxygen sensor? Just had a look at a R31/VL 3.0 ltr type, and they have the exactly same type of plug, so you can just screw it in and plug it in. A lot easier I think!
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
