SAU Friday Night Sessions - Live from the Northern Beaches 12/09/2003 8:30pm
  • Replies 64
Originally posted by Blitz
You sure you want to hang with us "coffee" drinkers izzo?:)
Yep... :shake:
Havent been down Bobbin Hd Rd before.... Whats it like ? :burnout:
LePpErFiSh...........
*IF* I come tonight (got battery issues but its charging well so should be fine) can we just "drive" tonight instead of "thrashing the living guts out of 15 lines to see who is quickest in a follow the leader race".
As usual i'll be towards the back just to enjoy the scenery (actually its because I can never keep up).
Did anyone else come across a Porsche 996 Turbo, Audi S3 and a BMW 540IL screaming down Pacific Hwy on the drive home?
I had just taken off from some traffic lights, when the Porsche came SCREAMING up behind me (it was raining :P ) and tailgated me for about 15 seconds before I changed lanes... He nailed it and went by me... Then the Audi came screaming past... Then the BMW tried to but it was slow :)
Stopped at the next light, they all surrounded me and the passenger in the BMW (which was beside me) leaned out, had a huuuuuuuge grin, and took a photo of my car...
Gave the thumbs up and off we went again... Played with them for about 5 mins until they turned off towards the Harbour Bridge... Was tempted to follow them, but cbf'ed :)
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
