Hi every1 just thought id let u know the hill climb champs that were run on the weekend was really good unfortunatly i only got 1 photo the whole weekend of micheles car in the dummy grid. It was good 2 finaly meet sum people on the forum. and congrats to neil in the radical and stu inwood for his times and a big congrats 2 michele for ur efforts for the weekend.
https://www.sau.com.au/forums/topic/244163-australian-hill-climb-champs/
  • Replies 55
Posted Images
cancel that, foudn the results here: http://blcc.com.au/dmdocuments/results010308.pdf
great work from stuart, 5th overall (first tin top) in a very tough field. just goes to show the 4wds are very hard to beat in a short event with a standing start. Looks like Neil had a tough day in formula libre, doesn't look like the right class for that car to me.
And well done to Peter Gumley, another overall win with combined 63.54
Can't see Michelle in the results, was there some problem or am I blind?
Those results are for March NSW Hillclimb, not the Australian Championships - Australian results weren't up last time I looked.
Raps, thank you for your help on the weekend. A big thank you to Neil who really was a great help on Thursday and Friday until my pit crew turned up Friday night.
I understand there were approx 134 entries.
Outright winners were
1st Gary West 21.73
2nd Andrew Howell 22.11
3rd Peter Gumley 22.33
Outright Ladies
1st Michele Guyer 26.81
2nd Amy Mrcela 29.66
3rd Mandy Tighe 32.03
Neil was put into Formula Libre 751-1300cc under protest (because he isn't an open wheeler) and came second with a time of 29.00
Michele came 16th overall
Neil came 29th :P
I will try to get some photos up for everyone, it was a fabulous weekend... I didn't want it to end. Makes me look forward to speed weekend even more now. I'll probably camp at McPhillamy Park.
Cling wrap works a treat :laugh:
Neil cried like a baby when he saw the ol' Capri :P
yeh, those pics really give you an idea how steep it really is,, hence hill-climb. :P
Its hard to capture "steep" in a photograph, but these do it pretty well. Thats why I chose them... what a spectacular backdrop!!!
I liked the row of tyres in the first pick :)
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
