  • Replies 77
Hi all,
Got a s1 r33 gts-t not long ago and am thinking about getting it serviced by a workshop instead of doing it myself like usual as I've gotten incredibly lazy.
I'm looking at getting a complete service done so just trying to figure out how much I'm about to throw out of my wallet.
Things i want to do:
all fluids
all belts
all filters
spark plugs
tune up
What do you guys reckon?
Who is the best to do this work but doesn't charge an arm n a leg?
you want the uleh tune cost lost mahet << the h is silent :D
100,000K service from boost works cost me $600ish so add a little more for extra belts which you prolly dont need and sparkies would set you back about $25 for coppers standard ecu doesn't go out of tune so that's really a buzz word
oil change is from memory $150 @ boostworx
Its done 104,000
well, more like "104,000" if you know what i mean... im guessing its in its mid to high 100's like most of em.
hence why id replace most of the stuff.
btw, the car has a flat spot at 5,000rpm on full power, not always there but sometimes it doesn't wanna go over without a fight. ideas?
im thinking spark plugs might be the (or part of) reason why.
sparkies usually give a popping type boost cut feel i would say not going over 5,000rpm could be dry solder on the AFM
i reckon i did my 100,000km @ 143,000 because i bought the car @ 123,000 and assumed it may have been done
also if you've boosted the car above factory it could be R&R stopping the car making peak performance so things don't go bang just nissans way of user protection
that's pretty much what it feels like, sort of misfiring but not so harsh.
the car is running stock boost.
where did you get your 100,000k service from? boostworx? what was done?
if u want a oil change, gear box and diff oil change i can do it for you. Brothers got a hoist i can use.
oils arent really a problem for me, i just thought if I'm gonna do it right might as well get everything done at one place as changing belts etc.. aren't something im confident in doing.
ill ring around a few places tomorrow but will let you know. :D
Edited by tx3_90
Its fuel cut. Try getting a stronger fuel pump or if that doesnt work fuel cut defencer (use only if the ecu is cutting you off not fuel pump itself). Its nothing to do with sparkies.
Edited by Rocky88
Ryan for a private service/tune, or Boostwerks for a shop service/tune
($450 ~ $650 for 1st and 2nd option is the going rate)
best if you buy the parts yourself, ie 5L premium 10/40w oil, oil filter, fuel filter, coolant, power steer fluid, brake fluid, diff fluid (attessa as well for us 4wd'ers), bcpre6 .8mm copper sparkies,
grab a gates racing belt set for $300 (belt, tensioner, pulley, rings/seals)
oil and water pump for RB, around $450 there for new
might need the exhaust studs checked at same time.
probably advisable to check and replace gaskets, ie exhaust manifold, intake manifold, turbo gasket
but doing that adds up to a grand job.
although you then know she's good for a fair while longer now, probably for your ownership.
a safc and nismo adjustable fuel pressure regulator might be a bit of fun, to get around the 5000rpm spot, and gain some more power
but youd want a full exhaust system, good induction and intake, better fuel pump, and then the mods really start
so easy to fall under the spell LOL
:P
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
