as the topic says has any used lewis engine rebuilders to rebuild their rb26 ? their prices are very competitive. Stockish full rebuilds with forgies and acl bearings cost $5500.00 . Their "killer" engine is just under 15k which includes all top name products . Their products are also very competively priced . Check out their website - www.lewisengines.com.au.
any feedback will be greatly appreciated.
cheers
https://www.sau.com.au/forums/topic/244244-lewis-engine-rebuilders/
cheers
Remember though, thats $5500 doesnt include anything other than stock pumps and nothing in terms of head work and/or oil restriction (nothing listed on the website), no mention of decent rod bolts etc etc.
Also bear in mind if your crank comes back fked, there goes another 1k right off the bat...
So that price isnt 'the best', its fairly hefty infact when you consider they dont do anything really, but then its not the worst i guess. IMO i'd rather have a racepace motor as once you add in the extra pumps pricing, head tidy up/bolts etc etc, your well within reach of something 'upper' class as i would call it
Realistically you'd spend at least another $1500 if you wanted to make any decent power... but hey, at least they'll give you a motor with belts set right :P
So not saying anything bad about them (cause ive got NFI of their work), i just think you should shop around :)
i think his refering to dirt garage aka paul aka twoogle aka red r racing
if you dunno him start googling lol
im under the impression that paul only builds engines and you supply parts?
also how would one send an engine interstate?
Edited by R32 Driver
Paul (DirtGarage) will build it for you, PM him and have a chat about what you want. Im pretty sure he can source you parts but you will have to pay upfront for them. Best to speak to him direct about it though.
Paul built my motor (RB26) not too long ago, There is a topic on it in here somewhere. His machinist does top quality work and doesnt charge a fortune!
Airroad direct will pick up the motor on a pallet and delver it. They are pretty cheap too. www.airroaddirect.com.au
Hope this helps..
Cheers,
Johno
Not sure of your location mate but have a chat to Dan: SAU Profile | Elite Racing Website
He has extremely competitive pricing and is a stand-up guy.
I have moved a couple of engines around interstate
Sent a RB25 from Brisbane to Adelaide through NQX ~$220
Sent a RB30DET from Melbourne to Brisbane through Mainfreight ~$240 - Mainfreight were the best to deal with and you didn't need to be a business customer.
i just bought a timing belt
ill install in on the weekend any tips boys im scared
Tips for the timing belt;
Cut it in half before you install it. And then just staple it back together. Easy way to install.
Start the engine and if it doesn't seize you haven't got the timing completely wrong, you might even be close.
You don't need a timing belt anyway. mine runs fine without one, i ripped it out years ago. get with the times
I see no reason to turn this in to a dirt pissing contest. His ability to build an engine is well documented.
We all have our favorite spanners but if i lived in adelaide there's no way I would be getting dirt or dan to do my work, There are good builders in all major centres, Why would you risk dragging engines half way round the country when it can be done locally.
Dan from elite is my builder and i wouldnt have it any other way. But If I lived near the dirt man I would have no qualms about getting him to screw my donks together.
(If he didnt leave a note taped to the engine telling me the timing belt needed tensioning tho I would firebomb his house :( )
lewis engines has been around for yrs ive had a few speedway heads done by him . he has a good backround his dad rip john lewis owned the dyno shop at st peters on payhan rd for many yrs b4 he was killed in a plane crash . his dad did sprintcar engines and drag motors many of the top runners at the time , ive had plenty of machine work done by lewis engines with no complaints
cheers mid life crisis
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
