as the topic says has any used lewis engine rebuilders to rebuild their rb26 ? their prices are very competitive. Stockish full rebuilds with forgies and acl bearings cost $5500.00 . Their "killer" engine is just under 15k which includes all top name products . Their products are also very competively priced . Check out their website - www.lewisengines.com.au.
any feedback will be greatly appreciated.
cheers
https://www.sau.com.au/forums/topic/244244-lewis-engine-rebuilders/
cheers
Remember though, thats $5500 doesnt include anything other than stock pumps and nothing in terms of head work and/or oil restriction (nothing listed on the website), no mention of decent rod bolts etc etc.
Also bear in mind if your crank comes back fked, there goes another 1k right off the bat...
So that price isnt 'the best', its fairly hefty infact when you consider they dont do anything really, but then its not the worst i guess. IMO i'd rather have a racepace motor as once you add in the extra pumps pricing, head tidy up/bolts etc etc, your well within reach of something 'upper' class as i would call it
Realistically you'd spend at least another $1500 if you wanted to make any decent power... but hey, at least they'll give you a motor with belts set right :P
So not saying anything bad about them (cause ive got NFI of their work), i just think you should shop around :)
i think his refering to dirt garage aka paul aka twoogle aka red r racing
if you dunno him start googling lol
im under the impression that paul only builds engines and you supply parts?
also how would one send an engine interstate?
Edited by R32 Driver
Paul (DirtGarage) will build it for you, PM him and have a chat about what you want. Im pretty sure he can source you parts but you will have to pay upfront for them. Best to speak to him direct about it though.
Paul built my motor (RB26) not too long ago, There is a topic on it in here somewhere. His machinist does top quality work and doesnt charge a fortune!
Airroad direct will pick up the motor on a pallet and delver it. They are pretty cheap too. www.airroaddirect.com.au
Hope this helps..
Cheers,
Johno
Not sure of your location mate but have a chat to Dan: SAU Profile | Elite Racing Website
He has extremely competitive pricing and is a stand-up guy.
I have moved a couple of engines around interstate
Sent a RB25 from Brisbane to Adelaide through NQX ~$220
Sent a RB30DET from Melbourne to Brisbane through Mainfreight ~$240 - Mainfreight were the best to deal with and you didn't need to be a business customer.
i just bought a timing belt
ill install in on the weekend any tips boys im scared
Tips for the timing belt;
Cut it in half before you install it. And then just staple it back together. Easy way to install.
Start the engine and if it doesn't seize you haven't got the timing completely wrong, you might even be close.
You don't need a timing belt anyway. mine runs fine without one, i ripped it out years ago. get with the times
I see no reason to turn this in to a dirt pissing contest. His ability to build an engine is well documented.
We all have our favorite spanners but if i lived in adelaide there's no way I would be getting dirt or dan to do my work, There are good builders in all major centres, Why would you risk dragging engines half way round the country when it can be done locally.
Dan from elite is my builder and i wouldnt have it any other way. But If I lived near the dirt man I would have no qualms about getting him to screw my donks together.
(If he didnt leave a note taped to the engine telling me the timing belt needed tensioning tho I would firebomb his house :( )
lewis engines has been around for yrs ive had a few speedway heads done by him . he has a good backround his dad rip john lewis owned the dyno shop at st peters on payhan rd for many yrs b4 he was killed in a plane crash . his dad did sprintcar engines and drag motors many of the top runners at the time , ive had plenty of machine work done by lewis engines with no complaints
cheers mid life crisis
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
